Hi-Po 5.0 Posted October 25, 2013 Author Report Posted October 25, 2013 Starting the build. Here we go. -.- 93' Exploder Deck:Pioneer 6400-bt Front Stage: Crescendo PWX 8"s and Skar Audio VX1-ST per door Amps: Sundown Audio SAZ-3500 v1 @.375 ohm daily, CT Sounds 125.2 Subwoofer: Two PSI Platform 2 18"s,Fully Loaded D1.5's Enclosure: B Pillar Fourth Order, 3:1 ratio tuned at 46 (Designed by Low Hertz Box Designs) Wire: All Sky High Car Audio Cable! Alternator: Singer 250 amp Hairpin Batteries: XS Power D975 Team Audio Connections
Hi-Po 5.0 Posted October 25, 2013 Author Report Posted October 25, 2013 Thanks for the input tho everyone. 93' Exploder Deck:Pioneer 6400-bt Front Stage: Crescendo PWX 8"s and Skar Audio VX1-ST per door Amps: Sundown Audio SAZ-3500 v1 @.375 ohm daily, CT Sounds 125.2 Subwoofer: Two PSI Platform 2 18"s,Fully Loaded D1.5's Enclosure: B Pillar Fourth Order, 3:1 ratio tuned at 46 (Designed by Low Hertz Box Designs) Wire: All Sky High Car Audio Cable! Alternator: Singer 250 amp Hairpin Batteries: XS Power D975 Team Audio Connections
Hi-Po 5.0 Posted October 25, 2013 Author Report Posted October 25, 2013 If total number of internal volume is 87.33% of the total numbe of all speakers FS, divide the sqaure root of the port area. If not, take the voltage of amplifier output, and subtract the sqaure inches of 2/3's the baffle only. It's easy dude. 15.4 cubes net. 2 18s, fs 24.5. 93' Exploder Deck:Pioneer 6400-bt Front Stage: Crescendo PWX 8"s and Skar Audio VX1-ST per door Amps: Sundown Audio SAZ-3500 v1 @.375 ohm daily, CT Sounds 125.2 Subwoofer: Two PSI Platform 2 18"s,Fully Loaded D1.5's Enclosure: B Pillar Fourth Order, 3:1 ratio tuned at 46 (Designed by Low Hertz Box Designs) Wire: All Sky High Car Audio Cable! Alternator: Singer 250 amp Hairpin Batteries: XS Power D975 Team Audio Connections
Hi-Po 5.0 Posted October 26, 2013 Author Report Posted October 26, 2013 So box either has to be tuned high (35) 222 inches of port area, and on the smaller side of reccomended box size (6cubes a pc) or big box tuned low but with 178 of port area. Whats the better trade off? More port area or lower tuning. 93' Exploder Deck:Pioneer 6400-bt Front Stage: Crescendo PWX 8"s and Skar Audio VX1-ST per door Amps: Sundown Audio SAZ-3500 v1 @.375 ohm daily, CT Sounds 125.2 Subwoofer: Two PSI Platform 2 18"s,Fully Loaded D1.5's Enclosure: B Pillar Fourth Order, 3:1 ratio tuned at 46 (Designed by Low Hertz Box Designs) Wire: All Sky High Car Audio Cable! Alternator: Singer 250 amp Hairpin Batteries: XS Power D975 Team Audio Connections
Tecomah Posted October 26, 2013 Report Posted October 26, 2013 If total number of internal volume is 87.33% of the total numbe of all speakers FS, divide the sqaure root of the port area. If not, take the voltage of amplifier output, and subtract the sqaure inches of 2/3's the baffle only. It's easy dude. 15.4 cubes net. 2 18s, fs 24.5. I hope you know he was joking or at least I'm 99% sure he was 750??! Yeah, fuck that. Fuck this website, fuck SMD, fuck Steve, fuck all of his butt buddy mods, and their couches.^ DON'T BE A DICK LIKE THIS GUY Team Subsonic Lows
Hi-Po 5.0 Posted October 28, 2013 Author Report Posted October 28, 2013 Well wall is built. 15 cubes net, 222 port area, tuned at ~31 93' Exploder Deck:Pioneer 6400-bt Front Stage: Crescendo PWX 8"s and Skar Audio VX1-ST per door Amps: Sundown Audio SAZ-3500 v1 @.375 ohm daily, CT Sounds 125.2 Subwoofer: Two PSI Platform 2 18"s,Fully Loaded D1.5's Enclosure: B Pillar Fourth Order, 3:1 ratio tuned at 46 (Designed by Low Hertz Box Designs) Wire: All Sky High Car Audio Cable! Alternator: Singer 250 amp Hairpin Batteries: XS Power D975 Team Audio Connections
n8ball2013 Posted October 28, 2013 Report Posted October 28, 2013 Abd then THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Hotdog Posted October 28, 2013 Report Posted October 28, 2013 need to think about the right build to cause the passenger seat to vibrate violently at 33hz. Then you wont have to worry about her hair doing the blowing. (NEW) 2004 F-150 Build Log -->http://www.stevemeadedesigns.com/board/topic/192208-hotdogs-f-150-build-log/ 2003 Mercury Mountaineer Build Log --> http://www.stevemeadedesigns.com/board/topic/114380-hotdogs-2003-mountaineer-build-log-20-removed/page__gopid__1602379#entry1602379 2008 Equinox Build Log --> http://www.stevemead...g/#entry1475764
Hi-Po 5.0 Posted October 29, 2013 Author Report Posted October 29, 2013 Abd? 93' Exploder Deck:Pioneer 6400-bt Front Stage: Crescendo PWX 8"s and Skar Audio VX1-ST per door Amps: Sundown Audio SAZ-3500 v1 @.375 ohm daily, CT Sounds 125.2 Subwoofer: Two PSI Platform 2 18"s,Fully Loaded D1.5's Enclosure: B Pillar Fourth Order, 3:1 ratio tuned at 46 (Designed by Low Hertz Box Designs) Wire: All Sky High Car Audio Cable! Alternator: Singer 250 amp Hairpin Batteries: XS Power D975 Team Audio Connections
n8ball2013 Posted October 29, 2013 Report Posted October 29, 2013 And its a typo. You built a wall. What happened THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
