keeping steady voltage
You said you set your gains with DD-1 and the -10db track. Basically this means that if you are playing music that isn't recorded at -10db you are likely clipping all to hell. Set your gains with 0db or -5db and check voltage drop again.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
You said that your voltage is stable when accessories are on and music is playing. right? However at a competition you're seeing lots of voltage drop, are you using pure sine waves? To and amplifier, playing music and playing a pure sine waves are different.
Pure tests tone have a full duty cycle that basically push the amplifier to its limit, its hard on the power supply. I had a setup like your and i could slam music all day with no problems, but playing 30hz wave dropped me down to battery voltage.
I've never been to a competition so I cant say for sure if this is your problem.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
yea like i can go full tilt on any song i want but when i get the run and i play my test tones, thats when the voltage drops. when i had my 160a alt my voltage was in the 10s with the tones and now it wont go under 12.2 with my new ult so def helping a lot, but ik im not clipping it at all, i mean obviously maybe a little but that is to be expected. if i were clippin, these subs would be destroyed im pretty sure lol im feeding them soooo much power. ik ppl that have blown their subs easily puttin that much power to the t1s becasue they dont know what they are doing
1995 Blazer lt 4dr
2 t1d412s
1 t2500.1bd
4 polk audio door speakers
2 dash speakers(coming soon)
1 amp to run my mids and highs(coming soon)
That alt with those bats, on that amp, should keep you at proper rest 12.8. Shit, you should probably stay in the 13s. Clipped or not.
Your making more that your pulling.Or damn close.....
Your said your starting battery is at 12.1 ? ???
Thats dead ...... charge it, or, replace it.
EDIT - also, test tones, (most of them,.. the better ones) are recorded at 0db.
So, you need to have 2 "levels" or "clicks" on your head unit.
One you play music with, set with the dd1, using the -10db
The other for tones, you use the dd1, and 0db track. You will have 2 seperate volume clicks your safe at.
The tone one, lower, obviously......
Understand?
ok, yea sounds good haha ive got a yellow top optima sittin in my garage right now that ive been plannin to change out for my starter battery, just havent had time yet, also idk if this is myth or not but my current starter battery is lead acid and my stinger bat is agm lol does that matter? i mean it wont once i change it out cuz the optima is agm but i was just wondering for future reference
1995 Blazer lt 4dr
2 t1d412s
1 t2500.1bd
  • 3 months later...
alright, bringing this thread back up cuz its kind of the same question. alright, ive got my dc 5k which im extremely excited about haha :) i am worried about my electrical a little tho, im about to run another 0 gauge wire from front to back so i will have 2 runs total but ive only got a yellow top in the front and a small stinger batt in the back along with the singer 350 amp alt of course :), im in college and obviously on a budget, im curious as to what kind of battery i can get to at least hold me over untill i can get more batts. or what would be optimal for me to get so ik what my next buys are going to be. thx for the help everyone, this will be my biggest build to date haha :)
1995 Blazer lt 4dr
2 t1d412s
1 t2500.1bd
  • Who's Online   0 Members, 0 Anonymous, 3374 Guests (See full list)
