Brandonbkd Posted October 31, 2013 Report Posted October 31, 2013 This could be your problem too. Haha did that catch on fire?? FI BL18 Build Log: CLICK HERE!! 2003 Explorer Sport: FI BL18 SoundQubed 2200 at 0.7ohm Pioneer DEH-2500UI Pioneer 6 x 8s Rockford Fosgate 6 x 9s 5 ft^3 box at 35hz Lots of Mega Mat
Blake Farrar Posted October 31, 2013 Author Report Posted October 31, 2013 i didnt swap doors but i swaped front an rear sets and i dont know how to mess with the fader and balance but im about to go look at it and see what i can do
Blake Farrar Posted October 31, 2013 Author Report Posted October 31, 2013 This could be your problem too. Haha did that catch on fire?? yeah it did those fuse holders suck i guess some of my wire was coming out of the post and made contact with the plastic and just went from there lol
Guest Posted October 31, 2013 Report Posted October 31, 2013 i didnt swap doors but i swaped front an rear sets and i dont know how to mess with the fader and balance but im about to go look at it and see what i can do then find the manual for your car dude. 95% of the time they're available on the manufacturers website.
Skullz Posted October 31, 2013 Report Posted October 31, 2013 First problem is wiring 2 components on 2 of 4 channels on a 4 channel amp!!!!! Wiring it down to 2 ohms will gain you nothing more in power that you could not achieve running them all on their own channel of the 4 channel amp!!!!! Stop making noob mistakes and use the damn equipment as it should be used, if you want more power than buy a more powerful amp to power them to start with. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
Blake Farrar Posted October 31, 2013 Author Report Posted October 31, 2013 before i had the ct sounds 125.4 i had a kicker 550.2 and it played both component sets at the same volume i dont see how it can really be anything else than the amp.
Blake Farrar Posted October 31, 2013 Author Report Posted October 31, 2013 First problem is wiring 2 components on 2 of 4 channels on a 4 channel amp!!!!! Wiring it down to 2 ohms will gain you nothing more in power that you could not achieve running them all on their own channel of the 4 channel amp!!!!! Stop making noob mistakes and use the damn equipment as it should be used, if you want more power than buy a more powerful amp to power them to start with. bro you're dumb just stop
Swordlordboy1234 Posted October 31, 2013 Report Posted October 31, 2013 If you dont do the exact test that i suggested by using a CONTROL door and using the variable of the amp channels then your setting yourself up for failure. Remember how most math classes you want 1 variable? Or any science fair thing, you have controls and a variable to test things....? Cars are not different. Dont switch front to back... USE A SINGLE DOOR TO TEST THE AMP. My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
SLAYER1805 Posted October 31, 2013 Report Posted October 31, 2013 Well you really wont know until you troubleshoot everything instead of trying to argue that its just the amp
Skullz Posted October 31, 2013 Report Posted October 31, 2013 alright so i bought a ct sounds 125.4 for my mids n high less than a month ago and i currently have it wired at 2 ohms on channel 1 and 2 with a sundown sa component set and a cresendo cz componet set. So who is the dumbass here? You using only 2 channels from a 4 channel amplifier or me pointing it out? 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
