carshateme Posted November 3, 2013 Report Posted November 3, 2013 If that isn't the case (the subs being different coils) it could be the box....one sub could be breathing more efficiencly than the other New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center]
Junior Russell Posted November 3, 2013 Report Posted November 3, 2013 i believe thats what omega was thinking but you never know it could be any number of things when it comes to audio http://www.youtube.c...e1?feature=mheehttp://www.stevemead...87#entry1993187 JVC KD-R530 head unit VVME INNO-D1500 sub amp Kenwood KAC-8402 amplifierPioneer 2-way 6.5 X2 @ 4 ohms DTI Audio 6.5 X2 @ 4 ohmsbox: 4.24 ft^3 tuned to 61 hertz (port walls fell off and dissapeared )
ChevyBoy95 Posted November 3, 2013 Report Posted November 3, 2013 if they are different, like dual 2 and a dual 4, then you will see about .7 ohms if you wired them to 1 ohm like you would if they were both dual 4's. check to see if they both read 3.8-4.1 per coil, or in parallel 1.8-2.2 per sub. Overall with 2 dual 4's wired down to 1, you should see .9-1.2 or so. edit: where is the port located, one could be loading differently causing it not to cool as efficiently. pictures? Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
Kyblack76 Posted November 3, 2013 Report Posted November 3, 2013 Is it the one closer to the port ? Or further way. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
moegej Posted November 4, 2013 Author Report Posted November 4, 2013 they are both dual 4's supposedly, havent checked them yet though. ive had them for about 2 months and i have them wired to 4 ohms at the moment. and the box is 3.8cu ft with a 6" aero right in the middle between them. all firing forward into cabin. 06 v6 Mustangbig 3Mechman 270 Hybrid G2 interstate batteriesBC3500 wired at 12 Sundown x-10 D4's
carshateme Posted November 4, 2013 Report Posted November 4, 2013 If they're 4 ohms...they shouldn't even be getting close to hot... New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center]
truthsayer Posted November 4, 2013 Report Posted November 4, 2013 they are both dual 4's supposedly, havent checked them yet though. ive had them for about 2 months and i have them wired to 4 ohms at the moment. and the box is 3.8cu ft with a 6" aero right in the middle between them. all firing forward into cabin. Wait if their both Dvc-4 ohms, then aren't you wired to either 1ohm or 16ohm. I'm confused on the 4ohm final load. truthsayer
Junior Russell Posted November 4, 2013 Report Posted November 4, 2013 He has them series and parallel each sub parallel and both subs in series 4ohms/2coils= 2ohmsx2subs=4ohms Make sense? http://www.youtube.c...e1?feature=mheehttp://www.stevemead...87#entry1993187 JVC KD-R530 head unit VVME INNO-D1500 sub amp Kenwood KAC-8402 amplifierPioneer 2-way 6.5 X2 @ 4 ohms DTI Audio 6.5 X2 @ 4 ohmsbox: 4.24 ft^3 tuned to 61 hertz (port walls fell off and dissapeared )
moegej Posted November 4, 2013 Author Report Posted November 4, 2013 i know they shouldnt even be getting close to warm at 4. thats what makes me wonder. its just the 1 that gets warm too. when i feel the 1 with my hand its warm and the other one is cool to the touch 06 v6 Mustangbig 3Mechman 270 Hybrid G2 interstate batteriesBC3500 wired at 12 Sundown x-10 D4's
CortezDTV Posted November 4, 2013 Report Posted November 4, 2013 One is probably out of phase Do a pop test by taking + and - out of the amp and connect straight to ur battery The subs should move out together the same amount, if one moves in or not as much it has a coil out of phase or if it moves the same amount as the other in an opposite direction (inward) that sub is out of phase SCSB Santa Cruz Speaker Box Build logs: Daily Driver Lemon Marquis 2 american bass 750.1s 350.4 on 14 focal 6.5s sq 945 on 4 hertz tweeters Mystery subs http://www.stevemead...__fromsearch__1 The Mustang 'dubbed' Shirley the project from bullet holes to badass http://www.stevemead...cond-skin-time/
