[fixed] Help! Mystery problem. I'm clueless
I've had this happen before to me, but it ended up being the amp. Have you tried a new head unit? I think you said you bypassed it, but if you had issues with the remote wire, then it sounds like there was an issue with the unit itself.
I'm stumped. I was going to say change the rca's too, but you've done that as well. You've essentially bypassed everything. When you swapped amps, did you hook it back up to the head unit or go straight to the phone.
Wondering if the head unit sent a bad signal or something and messed up something in the amps. BOTH amps. Maybe try a 3rd amp, only using the phone as your source and then go from amp's power to remote to turn it on. Bypass the head unit all together.
Just a thought. Trying to work some solutions in my head.
I'll check remote voltage after work.
Ground bolt is tight and corrosion free as well as wire
Thanks scooter I'll try that
MY BUILD
1998 Ford Explorer 2dr sport
1/0 Big 3 1/0 everything
Alpine cda-9884
Crescendo CZ components
(2) Crescendo bc2000's
(2) Jolt 150ah
(2) Yellow top optimas
(1) Juicebox black cherry addition
(1) Mechman 270 avbm
miss my bc5500 and (4) 15's
You know why people are ass holes online but not in person? Because getting punched in the mouth hurts.
have you tested different amp AND different subs?
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
I don't wanna seem rude but just read.
MY BUILD
Alpine cda-9884
(2) Jolt 150ah
Not to knowledged in trouble shooting but sounds like the head unit solely on the fact of. you said you bypass the head unit and things are dandy.....that leave the head unit. remote wire. and rcas. you did the RCAs. if its not remote wire. doesnt it have to be the head unit?
Yes he did.
yeah, I mean at the same time.
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
Read again. Bypassed h/u and the problem persisted. Not dandy
MY BUILD
Alpine cda-9884
(2) Jolt 150ah
Yes he did.
Yes same time
MY BUILD
Alpine cda-9884
(2) Jolt 150ah
  • Who's Online   0 Members, 0 Anonymous, 1038 Guests (See full list)
