[fixed] Help! Mystery problem. I'm clueless
My buddy called me because him amp shut off.
I installed this small system EXCEPT the h/u
http://www.stevemeadedesigns.com/board/topic/168025-05-s2000-single-12-all-fiberglass/
So I take a look at all connections
Power- good
Ground- good
Fuses- good
Remote- wire is good but will not turn on amp
run new remote, still no turn on
jump remote to power, amp turns on
install switch to control amp power
Amp is on, sub connections good, sub doesn't play but pulses every few seconds
check coils- good
New amp, same model, same pulse problem
New sub, different model, same pulse problem
New RCA, same pulse problem
Disconnect RCA, use adapter to play music from my phone through RCA, same pulse problem
With music playing and amp on, disconnect sub wires and reconnect, split second of normal level and then drop to low and pulse.
Confused. Discuss please.
MY BUILD
1998 Ford Explorer 2dr sport
1/0 Big 3 1/0 everything
Alpine cda-9884
Crescendo CZ components
(2) Crescendo bc2000's
(2) Jolt 150ah
(2) Yellow top optimas
(1) Juicebox black cherry addition
(1) Mechman 270 avbm
miss my bc5500 and (4) 15's
You know why people are ass holes online but not in person? Because getting punched in the mouth hurts.
bump
MY BUILD
Alpine cda-9884
(2) Jolt 150ah
that is crazy man. I am in just to see what it is lol
2000 Toyota Camry With Sealed Off Trunk
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
Two DC Level 4 m2 12s
80 Mil Murdetmat
Gathering Parts For Wall Build.
Team DC Audio 2014 Member
When you say wire is good. Define that.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Bad amp possibly?
Try another amp if you happen to have one laying around and see what happens if anything then you should have a better idea of the problem.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
clean all battery contacts alt, ground, and power
clean amp ground
i honestly am with skullz on this one on bad amp crunch my cousin had he didn't like it and neither did i it was an 1100.2 and it was a gutless pig
skar sk2500.1
0 gauge power and ground kunukonceptz
alpine HU
vxi65 components on BA gt-275
new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821
2 x-15 sundowns
singer alt, odyssey bat, and maxwell ultra caps
Monitor voltage on the power wires at the amp and let us know what it looks like.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
By wire good i mean no breaks. Unless it broke without the jacket breaking, hence why I ran a new one.
Guys if you read closer you would see that I replaced the amp. The replacement was one I used days ago on my pumkin system
Voltage at amp was in the 14's
MY BUILD
Alpine cda-9884
(2) Jolt 150ah
What did the remote power meter
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
have you verified that the bolt holding the ground lug to the frame of the car is still intact and secure and corrosion free? as well as the wire inside the lug.
  • Who's Online   0 Members, 0 Anonymous, 3472 Guests (See full list)
