Bump4life's SuperCapacitor Overview and Testing
What makes this configuration self balance ?
vs this configuration?
in the top bank of one of the ones i did, the capacoitors are hooked up in parallel first, then series.
where as in the second pic with black caps, the caps are series first then parallel. in any electrical config, a series connection allows for a voltage in balance. where as paralled connections will have same voltage. think about how you connect batteries. you parallel them so you have the same voltage.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
So if I hook a 12.3 volt battery in parallel with a 13.1 volt battery and resulting voltage is now 12.7 you are gonna say the 12.3 volt battery has no bearing on the overall capacity LOL
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
That config is NOT self balancing, unhook all the caps and check voltage on them after you do a 1000 amp pull on the bank
Evo X build log
Just to clarify, the caps that are parallel are balanced with each other cuz same voltage, but between each series they can't be, nothing is balancing them so each parallel row of caps is running an different voltages that is what I am getting at.
And like I said before for you since you aren't running at rated voltage doesn't matter much cuz you aren't using the full potential of the bank anyway, running DD can't go over 15.5 lol.
Evo X build log
what i am doing is playing the odds. i lay all my caps out and randomly choose 8 caps. since they are all within 20% tolerance i am betting that 8 caps create a bank that is near thier rating assuming 4 will be over tolerance and 4 will be under tolerance. thus if we get near rated caps, the series connections will be limited to a very small difference thus in a sense self balancing via parallel banks and trying to get near <1% tolerance in the parallel banks so when i series them there isnt much difference.
if you watch my videos i successfully burped all my dd amps from 15.7 volts. im not really sure where they shut off at lol. either way, after thinking about it, i guess in parallel they would be not to full capacity but i am playing the odds so at most they would be 10% of their max which is still plenty.
BMW M340 xDrive
The battle of the electrical guys is about to happen. All we need is the two Tony's to join with snow and you two then we will have a party.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
put it this way
caps > batteries
LOL
To an extent...I'd still run a battery or 2....last thing you want is to be at a show 100 miles away and have your alt crap out and then try driving home on just caps.
2000 Suburban 6 runs of 2/0
12 JBL Pro audo mids ,6 timpano audio tweets and 1 Prv compression horn per door
475ah of yin long LTOs
Triple 370 Amp Autotech Alts
mids amps 2  Crescendo Skyway 3ks
compreesion horn amp crossfire 800.4
Tweet amp Crossfire 2000.4
sub amp: 4 Crossfire XT 8ks
Subs: 8 18 in Crossfires in a 4th order
Best Scores at events…
163.5@38hz DBdrag  sealed on the dash… 164.3 outlaw…162.9 Meca headrest
But that's the issue. Batteries rely on a chemical reaction to produce current. If that chemical reaction is depleted or in one form or another interrupted, your current flow stops as well. Capacitors rely on a difference of electrons. They will produce current regardless of their resting voltage. You're comparing two things that really can't be in any way compared
You're misunderstanding what I meant.
Each capacitor in the row, due to how they are bussed together, will be self balancing with it's neighbor, because they are all wired in parallel. The wiring is such that you only need to worry about balancing 6 rows of caps, vs 48 of them individually
  • Who's Online   0 Members, 0 Anonymous, 4546 Guests (See full list)
