Bought a new car, it's an '03 Impala without OnStar.
I have prior experience with sound systems in my old car but I'm done with trial and error.
I picked out all the parts of my system, I need input. Pros, cons, what I should and shouldn't get.
Front Speakers: Alpine SPS-610c
Rear Speakers: Alpine SPS-619
Interior Amp: Polk PA-660 Class AB 4-channel 75wx4@2ohm RMS Wiring:4 gauge
Subwoofers: (2) Kicker compR 800wRMS 2ohmDVC, wired to 2ohms
Amp: HiFonics BRX2400.1d 1600x1rms@2ohms wiring:1/0 gauge
Dynamat for the trunk
Car already has an Alpine AVHX1500DVD 6.1" Touch screen head unit.
Should I get an additional alt? What about the Big 3?
This isn't an overnight purchase. As I get the money I will be purchasing
the components so let me know if I missed anything important
Thoughts, concerns, advice? All help would be appreciated.
Welcome to the forum, I have a 2004 impala. (pounds fists) Your plans look good. although the amps and subs could be better. (personal opinion)
Also, Knuconcepz wire is fantastic. power wire, rca's, fuse holders highly recommended, personally use. Not paid by them. Sky high audio has great power wire too.
You can probably get away with not buying an alternator if you do your Big 5 (our cars have weak spots in there design) and have a nice AGM battery
Build's consist of:
2004 Chevy Impala :
Pioneer--------------------- DEH-X8600bs Soundqubed/AQ------ Q4-120
Rockford Fosgate---- Punch-500.4
Soundqubed/AQ----- Q1-3500D.1 Alpine----------------- 6.5's & 6x9's
Subs: TBA All Knukonceptz and SHCA wire and rca's
Home Music Setup
(4) Soundqubed HDS200 15's in two separate 15.5 cubic foot enclosures tuned to 31 hrz --- XM radio hardwire
Updates coming all the time on both builds
n8ball2013
"bullshit. Everything fits. If you cut enough."
So you have about 900-1000 to spend(no elec)
And because you picked mainstream your getting a hell of a lot less and lower quality then you could get
Sub x2off
http://www.soundqubed.com/HDS300_c_34.html
Sub amp @1ohm
http://www.soundqubed.com/Q1-1200D-Amplifier_p_30.html
Or if you have the elec to support it at 1ohm
http://www.sonicelectronix.com/item_67936_Hifonics-BRX2400.1D.html?SearchClickout%5Bquery_id%5D=5701450&SearchClickout%5BIgnore%5D=1
Then idd spend the 160 you had set aside for front and rear and spend it all on front and get a good 2 or 4 ch to power them (and just keep stock In rear for now and turn them down)
  • Who's Online   0 Members, 0 Anonymous, 700 Guests (See full list)
