soundstream15 Posted November 14, 2013 Report Posted November 14, 2013 ok, so having a strange issue. last month my friend bought my AQ2200 from me, same day i installed my pure audio 3k amp, first song i played it was cutting out then i played another and seemed fine. well the issue is, when i go to turn my volume down it cuts out for a quick sec, it sometimes does it full tilt. like the song bitch better have my money, it cuts out full tilt. so me and my friend went over every connection, i have no loose ground or anything so we assumed it was a bad amp, so i sent that out and they sent me a new one. i got it yesterday and it still cut out! now when i did the DMM test to see how my amp was, thought maybe the amp is going into protect so when i played at idle and watched it. played same song that it cut out while driving, at idle it was perfectly fine. DAFUQ so i thought maybe its a loose remote wire, so i took a jumper and ran it from power wire to remote that way the amp stayed on and it still cut out. i took a DMM to read the voltage at the amp, and i was dropping to 12.3 at idle. while driving its 12.8 im so damn confused on how this is possible, i tuned the amp with the dd1 -5db. im thinking maybe its the rcas or head unit? as for electrical i have. big 3 yellow top under hood mechman 170a alt kitneik hc2400 in rear everything OFC 1/0awg wire maybe i have a bad battery that is reading fine but cant do anything under a load? help
n8ball2013 Posted November 14, 2013 Report Posted November 14, 2013 You replaced a good amp.with a turd. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
soundstream15 Posted November 14, 2013 Author Report Posted November 14, 2013 i like the amp better then the AQ actually..more power and sounds just as good...just saying
SoCaLBaMF Posted November 14, 2013 Report Posted November 14, 2013 Then why the problems? lol 2004 Bagged Trailblazer (4)18" Sundown Nsv3s (4) Taramps HD10000s, Taramps DSP3000, Lanzar opti 250x2, AB 100x4 (2)DC power SP 270s, (14)XS Power d3100s, (1)d6500
Skullz Posted November 14, 2013 Report Posted November 14, 2013 .2% THD@30% Rated Power. Holy fuck that sucks ass big time. Probably pushing north of 10% at rated power. lol 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
jk13 Posted November 14, 2013 Report Posted November 14, 2013 What are the subs wired to? Can the new amp run the same impedance as the old? Static drops are my bag.
Guest Posted November 14, 2013 Report Posted November 14, 2013 What are the subs wired to? Can the new amp run the same impedance as the old? 1 ohm on the pure audio amp makes each of the two internal amplifiers see .5. which is probably OP's issue, maybe, idk. should've realized that he was going to be changing from 1 ohm on a single amp, to 1 ohm strapped on two amps.
n8ball2013 Posted November 15, 2013 Report Posted November 15, 2013 i like the amp better then the AQ actually..more power and sounds just as good...just saying Um it doesnt even work how can you compare a working smp to what you have now THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
soundstream15 Posted November 15, 2013 Author Report Posted November 15, 2013 well fuck you guys lol lets say its not the amp, what could it be? i have a friend that has same amp and he has zero issues, so it cant be the amp. im wired at 1ohm.
