best cheap subs.... best cheap high excursion sub?
exxxtrem
the 2400 was the one my friend used for a long time, mostly due to his size constraints rather than any other reason. like i said he clamped it around 1900 watts at a little over 1 ohm, so thats pretty good compared to others in the price range. its efficiency is not very good though and if your someone that can really tell differences in a quality amp vs not so quality then you may not like it. But it ran great while he had it, and it abused it sa8v2, sadly he swapped in a new sa8v2 and forgot to reattach one of the wires and when he started his truck it fried the amp.
but like i said if you want to use planet audio stick with the big bang series and its decent for what you pay. as far as cheaper amps (supposed power vs cost), i personally dont know of any others, ive only used kenwood excelon, rockford fosgate, and currently powerbass and those have all done rated
Whats goin on, I didn't read all the threads so im just gonna give my personal preference. I started with budget builds and cheap stuff and I also have a cavalier. Its a 2000. I had some pretty bangy stuff for low cost. My real banger in a prefab box was 2 Diamond d3's. Dual 2's. Was on a Avionixx sxd 1600.4. In a MTX Bass Slammer. 33hz @ 3 cubes. Then a Boss Riot 2400.1 @ 2 ohms. I must say the boss amp won that battle. One sub blew (one was bad when I bought them) so wired the 1 left @ 1 ohm and gave it all the Boss amp had. It held up real good for months (the sub) til it went. But I abused the hell out of it. Big 3 stock alt. Now I have a 6.5 gross cu box with 2 lanzar opti's and 3 Autotek amps on backseat on rack. Built myself, saved tons and got deals on a lot.
Pioneer DEH-P5800MP
4-Kenwood 6.5's
2-Powerbass 6x9's
2-Autotek Street Machine 3200.1's
1-Autotek Street Machine 1400.4
2-12'' Lanzar Optidrives 1232d
1-XS Power 950 AGM Batt
1/0 AWG Stinger for Big 3
DB Link 4 AWG ran
they're both shit regardless.
edit: crescendo, soundqubed, and ct sounds/audio technix are literally your cheapest options for good amplifiers.
edit 2: http://www.ebay.com/itm/CT-Sounds-1400-1D-amp-amplifier-1800w-RMS-3000w-MAX-Class-D-1-ohm-stable-/111125861687 meade did an amp dyno video of this amp. did 2400w at 14.1v.
He just mentioned planet audio. In before he finds a shark 2500 and claims its the best 2500 watt amp.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
lol, i do agree with kranny on crescendo, soundqubed, and ct sounds. I personally plan on going the way of CT sounds once finances are available.
you cant be serious, that boss doesnt put out enough power to power my tweeters
Used to have a loud truck
So soundqubed 2k watt amp 450$
Ct sounds 1100$ um.. thats a bad ass amp
Havent found price on crecendo.
