Anyone with cap bank install?
They were used in a hybrid bus and are untested. So no guarantee they work properly.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
I did a write up here on super caps and a little testing. No balancing circuits used though
http://www.stevemeadedesigns.com/board/topic/178148-bump4lifes-supercapacitor-overview-and-testing/
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
I have an ~850 farad cap bank. You know how with voltage drop it's kind of all or nothing? Either you are holding 14v+ (or whatever your alt charges at) or you drop to 13v or lower.
Capacitors store energy. Not in the same way batteries do though. Batteries create energy though a chemical reaction - of which only takes place below the batteries "resting voltage". Capacitors store a difference in electrons - think like static electricity. This means they can absorb/release power at ANY voltage.
So in between your alternator's charging voltage and your battery's voltage potential (13v and below) - this is where caps shine. They basically act like a giant stabilizer. It cushions your drops, absorbs your peaks. I have a video of them which I'll post below. Been meaning to get a second one with the VM-1
that is just impressive results. 2 banks on how much power? a cross fire 8k? lol
BMW M340 xDrive
snowdrifter i believe has to banks, but he is also running xs p0wer 14volt battery, and charging above 16volts. Like you said @bump4life, higher voltage, equals higher capacity
*Hummer H3*
HeadUnit
Pioneer AVH-X4600BT
Mids and Highs
8-CT Sounds Pro 8" 8ohm
4-CT Sounds Pro Tweeters
Amplifiers
1-CT Sounds 125.4
1-CT Sounds 60.4
1-CT Sounds 7000.1
Electrical
3-Runs of 1/0 CT Sounds
8-XS Power D3100
3-Iraggi 300 amp Alternators
Subwoofers
4-SQ Hdc3 15" Subwoofers
(Soon to be 4 15" Ct Sounds EXO)
dirrrr
BMW M340 xDrive
I run 14v batts an 14 black caps an 12 blue ones.. Love my caps
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
yes but caps charge and discharge at a linear rate. so it doesnt matter what voltage they are used at. results should be same in a perfect world at any voltage as long as draw is the same
Linear..?
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/capchg.html
Charging current asymptotically goes to zero as it charges.
Then it exponentially discharges.
Energy stored in a cap = 0.5 * C * V^2
Since voltage is squared, energy skyrockets as you increase voltage.
This post sent with 100% recycled electrons.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
500F of Maxwell SuperCaps (soon to be 1000F)
iPadMini2
Dash mounted O-scope
Audison bitOne (Remote DRC MP)
Highs Amp - PPI Art A404
Hertz HSK130 (HSK165 waiting...)
DC Audio DC9.0K
2- DC Audio XL12m2
LEGAL             - 147.3dB @ 41Hz
OUTLAW         - 150.2dB @ 45Hz
OUTLAW         - 145.7dB @ 30Hz
JUNE 2014 SOTM WINNER
2014 COLORADO PEOPLE'S CHOICE WINNER
SOTM BUILD:
http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
Linear..?
Now now, lets not blow OPs mind quite yet :)
learn me :) lol guess i was thinking wrong thing. makes sense though.
linear. dirrrr, i have much to learn still
BMW M340 xDrive
