WTF amp installation kits?!
Okay, can anyone tell me why the hell amp install kits are cheaper than buying everything separately (a great advantage for the customer) yet never have the 18ft. of neg wire...seriously, what the hell?! I understand you'd want a length to ground everything, but my amp needs to connect to both battery leads in order for it to work.
/stupid
masterbation is free, and even saves you money.sorry but someone had to say it
sorry, Jimmy...beat you to it (no pun intended)
LOLDON'T get a wife. Best advice I never got, and now it's too late <_<
My build: 12" DCON in a dorm room.
New/current build: 8" woofer, custom amplifier block, fiberglassed speaker pods
Ground in the back to the frame. There's no reason to have a ground run to the front battery.
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
What are you grounding to that you need 18ft of negative? Just ground to the shock tower or frame. Unless your car is made of plastic or something
^ That's what I was going to say..the process supposed to appeal to consumers and your ranting? lol should be glad it's cheaper this way
Amp sets are cheaper because it's a bundled price. So you sort of answered your own question. And like every one has said, i cant think of any situation you would need a long negative cable.
truthsayer
if anything you'd want the shortest ground possible.
In my car I get less voltage drop with a quality chassis ground than I do with a negative run to the front..
2010 Honda Civic LX / Deck: Kenwood DDX371 / Front Highs: Crescendo RTS-1 / Front Mids: Silver Flute 6.5's / 4 channel: DC Audio 90.4 / Sub: Fi 15in SP4v2 / Sub amp: Taramps HD 5000 / Power wire: Knukonceptz OFC 1/0 / Deadener: Audio Technix 60 mil / Batteries: XS Power D5100R / Rear bank: TBD / Alternator: Singer 240a hairpin
the shorter the neg the better
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
So now it sounds like I actually may be mentally handicapped....positive terminal of the amp goes to the battery, negative terminal just connects to anywhere you want to ground it?
  • Who's Online   0 Members, 0 Anonymous, 3465 Guests (See full list)
