skaraudio Posted November 25, 2013 Report Share Posted November 25, 2013 (edited) Today I put together box designs along with cut sheets for the VVXv2 Series Subwoofers, in both Single and Dual Woofer Designs... If you are looking for a strong and great sounding enclosure for your VVXv2 woofers, these will be perfect depending on how many and which size woofer you are running as they were designed specifically for these drivers =). Simply browse the designs below and click the associated link for the PDF File which will give you the cut sheets as well as other specifications. These boxes are relatively simple to put together if you have the basic tools required and are clear cut so as not to be confusing how to assemble. All designs can be found at Skar Audio - Where Audiophiles Meet Excellence > Knowledge Base (Footer Link) as well as in this thread.. We will be coming out with designs like this for all of our different woofer lines specifically for each series, so stay tuned if you have other Skar Audio speakers. Single VVX-10v2 Ported Enclosure Design & Cut Sheet (PDF) Dual VVX-10v2 Ported Enclosure Design & Cut Sheet (PDF) Single VVX-12v2 Ported Enclosure Design & Cut Sheet (PDF) Dual VVX-12v2 Ported Enclosure Design & Cut Sheet (PDF) Single VVX-15v2 Ported Enclosure Design & Cut Sheet (PDF) Dual VVX-15v2 Ported Enclosure Design & Cut Sheet (PDF) Edited November 26, 2013 by skaraudio Skar Audio www.SkarAudio.comPhone : (888) 501-7527 Link to comment Share on other sites More sharing options...
n8ball2013 Posted November 25, 2013 Report Share Posted November 25, 2013 waits to see how long the will this design work with xxxxxx woofers too start to come rolling in THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
[email protected] Posted December 5, 2013 Report Share Posted December 5, 2013 Those are with 3/4" thickness? Link to comment Share on other sites More sharing options...
skaraudio Posted December 20, 2013 Author Report Share Posted December 20, 2013 Those are with 3/4" thickness? Yes! Skar Audio www.SkarAudio.comPhone : (888) 501-7527 Link to comment Share on other sites More sharing options...
oldsoundguy Posted December 20, 2013 Report Share Posted December 20, 2013 Wow this is a great Idea. Takes the guess work out for you subs. 80prs Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier Incriminator IA 10.1 Focal PS 130v 5.25 (doors) 4" Faital pro Neo (kick panels) 3" Faital pro Neo and focal tweets( dash) DC Audio level 3 12" custom box designed by joex built by me AGM front, XS 750SE batteries rear DC 180 alt 99 Toyota Tacoma extra cab http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/ Link to comment Share on other sites More sharing options...
skaraudio Posted December 25, 2013 Author Report Share Posted December 25, 2013 Wow this is a great Idea. Takes the guess work out for you subs. Should make things a bit easier for those customers just getting into the hobby =) 1 Skar Audio www.SkarAudio.comPhone : (888) 501-7527 Link to comment Share on other sites More sharing options...
bigp_on_the_beat Posted February 2, 2014 Report Share Posted February 2, 2014 (edited) Anything for VVX v1? Or would the v2 work with the v1?? Edited February 2, 2014 by bigp_on_the_beat 1 No car at the moment. New system: 2 Skar Audio VVX-12s Crescendo bc2000d Carquest NGT battery (back) Deka battery (front) Link to comment Share on other sites More sharing options...
skaraudio Posted February 4, 2014 Author Report Share Posted February 4, 2014 The v2 Designs should work just fine with the v1 VVX Woofers! Skar Audio www.SkarAudio.comPhone : (888) 501-7527 Link to comment Share on other sites More sharing options...
bigp_on_the_beat Posted February 4, 2014 Report Share Posted February 4, 2014 The v2 Designs should work just fine with the v1 VVX Woofers! Thanks so much, can't wait to get my subs playing it's been a 2 years without music. No car at the moment. New system: 2 Skar Audio VVX-12s Crescendo bc2000d Carquest NGT battery (back) Deka battery (front) Link to comment Share on other sites More sharing options...
jmanjr82 Posted February 27, 2014 Report Share Posted February 27, 2014 using torres and inputting the specs on the skar website there is something wrong: Skar website: Outside Dimensions : 19” Wide x 20” Deep x 14.5” High says gross volume is 2.0 Ft ^3 Torres Calculator: Outside dimensions : 19” Wide x 20” Deep x 14.5” High says gross volume is 2.44 Ft^3 That difference is kind of a big deal especially since the skar site says its tuned at 32hz where as torres says its tuned at 39hz? I am basically trying to figure out why there is such a big difference as I am trying to design a box for a honda accord, but the information isn't adding up. Link to comment Share on other sites More sharing options...
