How to set gain on saz3000 when max gain is 6v but line drivers 8v
Deadly hertzz
I camt watch the video
You bypassed the linedriver right?
Your rca still has a signal at the amp right. Make sure you have a good ground.
Try using a different speaker output try the pos then the negaticw until you gwt signal. Sometimes you dont get signal until a certain volume.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
This is all with the line driver out of the equation I can get it to detect the 40 but never the 1khz could it be since it's from the sub output on the head unit it wouldn't send a tone that high through that RCA or something
8 sundown sa 12s walled
Saz3000 at .5
HO alt
All ofc Sky high wire
Alpine components
Rockford power mids
imagesCAA9EA5N_zps0f411022.jpga5ec9a01-b60c-4312-9001-236b48dfe6b0_zpsb01ef146-7fd0-47c3-90e9-f1a2d4595b03_zpsimagesCATNMRMV_zps66a8566a.jpg
I have everything set on the amp just like the manual says everything flat on head unit hpf off loud off there's a sub control feature that goes from 60-300hz and I put that all the way up also
Saz3000 at .5
HO alt
Alpine components
Rockford power mids
