Regular Cab truck Box
I'm running 2 sd-2 10d4 in seperate boxes an they play decaf lovely and hit the low nice and they are sealed like I said jacob told me the 10's are design for seal but can be ported and also if sealed I can put 700rms to each sub with out harting the sub
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
Didn't really read it all but i have a single cab too and i had good luck with porting towards the roof on the drivers side I would definitly go ported
My setup,
Digital Designs M80
3 Re audio 10's ported tuned to 36 hz
Kenwood x-696
SHCA 0 gauge
Polk audio coax running off hu
Are those Spots for 6x9's next to each sub driver?
Edit: Was on mobile and didn't see that they are separate enclosures.
I recommend getting rid of those and use that money for quality door components.
Krakin's Home Dipole Project
A slot port on an angle doesn't quite work well like how you have it. I would also ditch the 6X9s. That is also using precious airspace that could otherwise be dedicated to the subs.
For a regular cab, you should really look into aero or round PVC ports. And I wouldn't go smaller than 1.5" wide on a slot port. Total port area is the important thing here. Which sub are you designing the box for? Port area can be suggested if we know for sure. Are you still planning on the Sundown SD series? Which size?
I would highly suggest running the SA8s, they'll be impressive to you if you've never heard them. They are beefy drivers and perform very well in ported enclosures ,
Round pvc ports, to the side, seems to always work best. 2 or 3 3 inch tubes, or 2 4 inch tubes, is probably your best bet. I had a single 10 with 2x3 inch pvc ports and felt like it could have breathed a bit more...but on the other hand, I have a friend with a 95 regular cab chevy with a single 12 and 2 4 inch pvc ports, and his box is way peaky with those big ass ports.
  • Who's Online   0 Members, 0 Anonymous, 622 Guests (See full list)
