That Loud Focus...USAlternators Hairpin, 4 DD 9515i's in a B pillar on 2 Soundstream XXX-15K's. Caps and Lithium Power. New vids
not to burst your bubble but you wont fit 2 dd 18s behind your c pillar. i would be surprised if you can fit 2 15s in optimal space. b pillar wall or bust.
the js are insane though. good choice :) i suggest yuou spend cash on electrical before new subs! and also i still dont understand how you went fron an xs d3100 to a juicebox battery.
either way. im tuned in for results as ususal
Cause a juicebox is better than no battery lol
Brandon
2000 Furd Ranger supercab 4x4
System:
welding wire throughout the truck
USalts 390amp Hairpin
Juicebox in stock location
8 Banks of maxwell supercaps
2 American Bass Vfl 1100.1 wired to .35 each
2 Fi Audio Sp4 18's ( the DD sc 9918's smoked)
Pioneer radio with Soundstream PA mids Powered by a nice sized soundstream 2 channel
It's pronounced (dain-ja rain-ja) :ph34r:
2001 2 door focus
1 DD9918 SC
Bottom depth 30"
Top depth roughly 17"
Width 41"
Height 20-21" to top of back seat.
Taking from my 03 zx5 focus.
The roof I'd roughly another 20" at most but slants back and is shorter near the sides.
Sorry but I don't see 2 18s fitting a no that is 41" wide x 40" tall x 30"depth 1 x 17" depth 2. Even with using the spare tire well.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
2 15's can be done for sure in a no wall style enclosure. I did a 154.3 sealed on the dash in my ZX3 with 2 Nightshade 15's and a pair of Sundown 3500's. I would suggest going that route because the car doesn't need to be built the way you are doing it to get loud. Do what you want but there are better options. My loudest setup in the car was 4 Sundown sa12's and 4 12's is about the most coins area that will actually fit in the hatch.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
146.4 sealed on the dash at 37hz
2001 Focus ZX3: RETIRED
Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore Champion
Highest NSPL Scores to date:
154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz
155.2db unofficial on dash at 43hz
if i can fit two 18s in a trunk he can fit 18's in a wall.
1997 subaru legacy outback
Four 15's in a almost wall
Rockford Fosgate t2500-1bdcp
Rockford Fosgate T400-4 on tweets
Rockford Fosgate T400-4 on highs
Rockford Fosgate T400-2 on midrange
Rockford Fosgate T400-2 on midbass
Optima Yellow top batteries
270A Singer alt (working on a bracket for a second)
Lots of Second Skin
Nit saying it can't be done but not with keeping the back seat
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
It may be able to be done but there is no way it is optimum. Why waste your time when you can be louder with a well thought optimum enclosure for the correct sub setup? Like I said he can do what he wants but it won't be as loud as a no wall setup in that car. I may have a bit of an idea about the vehicle since I have the loudest recorded no wall score ever in a Focus ZX3.
1 XS Power D3100
Audio Control LC6i
Stock Deck
For the record I have a zx5 so idk if and how it differs. idk what I am exactly going to do yet. I am doing a c pillar though. I have wanted one forever. but I really don't want 2 15's. I'm going to measure out everything and see exactly how much area I have to work with and go from there. like I said if I cant do it I cant. I would do like 4 10's or something but those J's are expensive lol. only can afford 2. maybe I could do a 4th....idk. not set on anything yet. I gotta think about it a bit.
2007 Ford Focus SES Hatchback
Pioneer HU
4 Digital Designs 9515i's in a B pillar.
2 Soundstream XXX 15K's (running at 16 volts)
Soundstream Mids/Highs in custom door panels (getting rebuilt soon)
Soundstream TA2.160 and TA2.400
Sky High and KNU wiring
3 Banks of Maxwell caps
Winston Lithium (not a fan)
Bump4Life 250 Amp Alt. aka USAlternators
Soundstream Focus and Avenger Build Log
Instagram @p4linnovation
YouTube: Team Blowin Loud
Everything looks pretty good here. Nice job on the doors for your first go round. Learn lots doing it yourself.
Ok so now I feel obligated to ask the question, cause this makes no sense.
As far as my friends car I will not be posting any more pics of his in this log. his current setup will probably be it for now. shortly after slam his engine seized. long story short whoever did his oil change put the oil filter on wrong so the story tells its self. he will be getting a new engine put in and once he does he will more than likely be walling shortly after. if and when he does I will create a separate log.
HOW THE HELL DOES ONE PUT AN OIL FILTER ON WRONG?! This is basic mechanics 101. It has one hole, that screws on one threaded tube in the engine. It's not like it can be put on backwards. I know it's not part of the thread, but really, I'm extremely intrigued to know how this happened. That story doesn't tell itself, that story begs to be told because it just simply isn't easy at all to eff up putting on an oil filter! An effing monkey can do it!
It was put on using a wrench and over tightened. it cracked and slowly leaked out.
Pioneer HU
were your 2 18s loiuder than my 2 12s out of the trunk?
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
lol you dont count, badass electrical and a shit ton of power on top of absurdly badass Z's
Brandon
System:
2001 2 door focus
1 DD9918 SC
  • Who's Online   0 Members, 0 Anonymous, 1032 Guests (See full list)
