DC Sound Lab
Box Recommendations
I understand that most of those who posted calculate optimal port area by using a formula. My question though is how many actually use that recommendation? The reason I ask is because that seems like a ton of port area.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
The boxes that I have seen JoeX post use the same formula's.
Bkolfo4 builds his enclosures with it
CleanSierra has built many boxes which I assume they all use the recommended minimal vent area.
But do remember that these suggestions are not golden, Small stated in his second paper that the formula is only accurate up to +10%, and must use a reasonable radius for flaring. He later states that an acceptable limit is to design to 5% the velocity of sound.
I however can only reference work done and documented, as I haven't been able to find the time to test it all myself.
Edited by Krakin
Krakin's Home Dipole Project
Having less than recommended port area still works, you just have to look at each setup and determine what you are trying to do and what sacrifices you are willing to make.
Couple of examples:
David Moore was doing 154+ on 2 RE MT 15's with a total of 48 sqin of aero port.
In the great 12" challenge years ago, they did 150 with a single BTL 12" on 5000 watts with a single 4" aero.
I've built several using the port area formula that I suggest and I have yet to make a peaky enclosure. I realize CJ has specific knowledge of real world experience with the subs in question. I've heard the Level 4s on a DC 3.5K I'm the same vehicle with two very different enclosures. They were in a forum member's vehicle with equipment that Cody sold him. The first enclosure had like 36" of port and got loud at tuning but fell on its face above and below tuning. The second enclosure has around 80-90" of port and it's way more musical and not nearly as peaky. The rolloff is much less noticeable and it's got more range for sure. The system sounds better with the larger port area. Granted, the first enclosure was UNDER what Cody suggests, so maybe it's not a fair comparison.
I have yet to have port noise in an installation and I have yet to make box that doesn't have good musical range.
I know Brian, Bkolfo, HATES the port area per foot recommendations because a sub needs X amount of port regardless of what airspace it's in. Xmax, tuning and cone area are supposed to drive the port area for a drive to operate efficiently, according to Small and all collected in the Loudspeaker Cookbook by Vance Dickason. I know there is a difference between theory and application though and I've built enclosures with less that the "mimimum" recommended. I've still tried to stay close since I believe in the formula.
Just making it clear, I was just makin a funny not trying to start a port area war haha
I knew you weren't starting a war :) We are all good bro.
I was just stating my approach to enclosure design in regards to port area. I think Xmax is an important factor in port area design. The part where it gets tricky is I'm not sure how accurate some of the company's Xmax figures are. Not DC specifically, but some I've seen that make me wonder.
I would also agree a single flared 8' port would be perfect of the pair of DC Lv 4 10's since the port velocity is there as well.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
  • Who's Online   0 Members, 0 Anonymous, 358 Guests (See full list)
