Rockford Fosgate T400-4 questions
Jhunt94
You could get 2 pairs of 1 female to 2 male splitters on the fronts and just use rear for your subs like it is. If you were running the same sets of speakers then you could have just switched the amp to 2 ch mode
So if I switch it to 2 channel mode it will just use the signal from one set of rca's?
yes but you have different speakers in front/rear so it wouldn't do you any good as one set or the other won't have proper power/eq adjustments on them.. Just get some $5 rca Y splitters and use the front channels like was already said by someone else until you get a hu
Okay thanks!
2007 Ford F-150 Reg. Cab. Flareside
250 Mechman Alternator
Sky High Car Audio Big 3
XS Power D3400
Rockford Fosgate 1/0 amp kit
Rockford Fosgate T1500-1bdcp
DC Audio Lvl 4 12"
Rockford Fosgate Punch 6.5" component
Rockford Fosgate Punch 6x8
Pioneer AVH-P2300DVD
SMD Volt Meter
What speakers are connected to.the t400.4? If all you have on the 4 channel is some door speakers with x-overs then put it in 2 channel mode until you can get a CD player that has 3 RCA pre outs, about 4 volts our higher would be nice to.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
What speakers are connected to.the t400.4? If all you have on the 4 channel is some door speakers with x-overs then put it in 2 channel mode until you can get a CD player that has 3 RC pre outs, about 4 volts our
I have a set of punch 6.5 components in the front doors and a set of punch 6x8 in the rear doors. The components are 60 watt rms and the 6x8 are 65 watt.
XS Power D3400
DC Audio Lvl 4 12"
SMD Volt Meter
The rear/sub output is set to sub out. So you wont get a full range signal.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
On the headunit? Is there any way I can change that?
XS Power D3400
DC Audio Lvl 4 12"
SMD Volt Meter
Should be able to. Get out your manual and find out
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Alright thanks!!
XS Power D3400
DC Audio Lvl 4 12"
SMD Volt Meter
2 channel mode shouldn't be any different that using splitters.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
Well putting it in 2 channel mode definitely worked. When I find my manual I'm going to see if I can change the subwoofer outputs to rear.
XS Power D3400
DC Audio Lvl 4 12"
SMD Volt Meter
  • Who's Online   0 Members, 0 Anonymous, 769 Guests (See full list)
