DC Sound Lab
Hello!
So. This is my first post here.
Im looking in to upgrading my setup. I live in Denmark, and don't have that many choices as in the states.
My budget is around 917usd (5000DKK) just for the sub/amp
And for exactly that amount, i can get the Level 3 12" and the 1.2k.
(For the same price as the level 3, i could only get the Sundown E 12 v2 or the DD1512. - I could be wrong? but looking at specs, it's not a hard choice)
Would the level 3 and the 1.2k be a good match? Or would the level 4 be a better choice?
The lvl 4 would mean adding another 110usd to the budget. That isnt that big of a dealbreaker. But i'd rather save them for the rest of the setup.
well if you want more out of the 1.2k yes the level 4 would do better you can always turn down the gain on the 1.2k with the level 3,
welcome to the forums
Welcome to the forum!
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
Thanks guys!
Gotta wait untill January, before the cash is there. Gonna be a long wait :P
The electric side is coming along. My pug 206 diesel has a stock 150a alt, 1/0 gauge front to back, and doing the big 3 soon. (AGM battery is also on the to-do list... with many other things :P)
Specs for the level 3 says 1.5cuft ported, that is after displacement right?
- What is the woofer displacement, and how much port area is optimal? (The pug 206 has a pretty small-ish boot)
Thanks guys!
I assume the 1.5 is after displacements, the level 3 12" displaces .16 cubes.
You could go with the usual 12-16 square inches of port per cube or try to optimize a port based on xmax of the driver.
- 2012 Mustang 3.7 Manual
- Audio under construction
Welcome.
2017 Chevrolet Silverado LT CC - Will be running 2-3 DC Audion M3 8s, unsure of amp, Mechman 320 amp alt.
2005 Ford F150 - Bagged on 24s, fully shaved, raised bed floor.
Thanks guys!
@Shanesauce
Oh, yeah... overlooked that in the specs, but thanks
I've just downloaded Torres box calc, and can't really figure it out. If i put in numbers for a box thats 50 liters gross, and 4.5 woofer displacement, no matter how insane numbers i give the port, the net result never changes from 46.5? and if i change it to inches/cuft, gross can only be whole cuft, not like 1.5 or 1.65 and net only changes if i put in woofer displacement.
If anyone would help me out with a box design, i would be very thankfull.
H - 14.96 / 38cm
L - Not more than 38ish (hopefully not THAT long)
D - 12.5 / 32cm
@32-33ish
Slot port would be cheapest (i think?), but aero port designs are also welcome :)
  • Who's Online   0 Members, 0 Anonymous, 9437 Guests (See full list)
