Gauge Size
gattiboy13
What amp is it cause most high powere 4ch amps use 4 gauge
XS Power D5100, 2 D2700s, & 2 D975s
MechMan 220a Alt
DC 5K
Kicker 650.4
2 12 Ascendant Audio Mayhem's
Pioneer DEH-P7200HD
Rockford Fosgate 3sity.1
Build log: https://www.stevemeadedesigns.com/board/topic/166792-88-nissan-maxima-trunk-build/#entry2430899
https://www.stevemeadedesigns.com/board/topic/191439-lexus-is300-fi-crescendo-shca-rf-pics/
Regardless of what brand is it being an 8 gauge amp mean anything as far as it actually putting out what it says is cea compliant at 150x4 at 4ohm and 200x4 at 2ohm?
yeah the brand kind of matters...depends if the amp is overrated or not. or if you're cutting it close to the 8 gauge amperage limit for a 15-20ft run of wire.
from an electrical standpoint 8 gauge can carry roughly 50 amps of current over 15-19 feet. that's the average length of a run in a car.
50 amps of current at 14.4 volts is roughly 720 watts. divided by 4 is 180 watts per channel.
So yes Virginia there is a Santa Clause and 8 gauge in can do 150 x 4
Rolex you sicken me.
Just let me finish my pie
~ Juice
Just to add to this, Rated at 110 x 4 there should be no question this amps does 150 x 4 @ 4 ohms and guess what we have hard wired directly to it from Zed......
8 gauge
So is it possible, yes! will you get it, depends on the build quality of the amp
/ Thread
~ Juice
  • Who's Online   0 Members, 0 Anonymous, 683 Guests (See full list)
