conbon Posted December 12, 2013 Report Posted December 12, 2013 ive had some sites tell me it is and that it isnt but is the Hifonics ZRX1000.1D 1 ohm stable? i wanted to see your guys answers, bc i dont know who to trust 2013 Ford Focus Hatchback SE Kicker CS61234 Kicker 40CS674 Kicker KST25 Sundown Audio SA-12 D2 Rockford Fosgate t1000-1bdcp Rockford Fosgate t400-4 Audio Control LC7i Kinetik HC2000 0/1 Gauge Big 3 Upgrade Beer, babes, and bass.
hazestorm23 Posted December 12, 2013 Report Posted December 12, 2013 It is one ohm stable but its even less reliable at that low of impedance. Do you already have it?
gattiboy13 Posted December 13, 2013 Report Posted December 13, 2013 It is 1 ohm stable but on this amp i would not put more than 700 watts of rms to it at that low ohm load. If you try and put a quality sub that is more than 700 i am sure you will have heat issues as well as it going in protect. Go with Brutus line if anything, same board design but much better components.
Chance_P Posted December 16, 2013 Report Posted December 16, 2013 I had a zrx 2000.1 at 1 ohm with no issues. Def was not putting out rated power though.
sickbass Posted December 16, 2013 Report Posted December 16, 2013 It is 1 ohm stable but on this amp i would not put more than 700 watts of rms to it at that low ohm load. If you try and put a quality sub that is more than 700 i am sure you will have heat issues as well as it going in protect. Go with Brutus line if anything, same board design but much better components. wait.. are you saying that lower ohms means lower power? what is tha i don't even.... dafuq put power to amp?
Broke_Audio_Addict Posted December 16, 2013 Report Posted December 16, 2013 It is 1 ohm stable but on this amp i would not put more than 700 watts of rms to it at that low ohm load. If you try and put a quality sub that is more than 700 i am sure you will have heat issues as well as it going in protect. Go with Brutus line if anything, same board design but much better components. How much power your sub can handle has no effect on how much power your amp is or is not going to put out or how hot it will get. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
kirill007 Posted December 16, 2013 Report Posted December 16, 2013 It is 1 ohm stable but on this amp i would not put more than 700 watts of rms to it at that low ohm load. If you try and put a quality sub that is more than 700 i am sure you will have heat issues as well as it going in protect. Go with Brutus line if anything, same board design but much better components. Please don't answer anyone's question concerning audio any more please. (you also don't seem to react to your own threads.) And to the topicstarter: Look here (It's the fourth link if that helps you more, the pdf...) Thinking is the root of all problems... You ALWAYS get what you pay for.
gattiboy13 Posted December 16, 2013 Report Posted December 16, 2013 Sure you sub watts matter. If you put a DC level 5 on a power acoustic 500 rms your gonna blow amp. And who said lower ohms means lower power? That is retarded...i said put a better quality amp on his sub. That zues wont handle his sub, it will burn out
gattiboy13 Posted December 16, 2013 Report Posted December 16, 2013 I meant if you have that amp at 1ohm to a 1,000 watt sub it wont do to well and more likely burn out. Now if you put a sub that was lets say 600-700 rms it might push it ok. But for your needs go with Brutus if anything.
hazestorm23 Posted December 17, 2013 Report Posted December 17, 2013 Sure you sub watts matter. If you put a DC level 5 on a power acoustic 500 rms your gonna blow amp. And who said lower ohms means lower power? That is retarded...i said put a better quality amp on his sub. That zues wont handle his sub, it will burn outThe amp will not blow up if the sub has a higher RMS rating , it just means the sub won't be pushed to its potential. Heck Steve Meade wired a 500 watt Rockford to a 18 fi and it moved it pretty good its just not going to sound the same.. and as for as his amp yes it will push it just not anywhere close to where it should be. It would only mess up the amp if it was wired at a lower impedance than the amp allows it.
