Subsonic Filter
gattiboy13
depends on a few factors
is you box ported, what are you ported to if yes
how much power are you giving your sub(s)
how much air space are you running , port area ?
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
good question, if you have a sealed(4th order) does it matter where you set subsonic? I have a general ideal of how it affects tuning on ported boxes,
supercharged hummer h2
8 Sundown nightshade v'2 Scott Bowman built 4th order bandpass
2 precision power pcx 4125(mids & hi's)
2 Stetsom 14k2e's
alpine ina-w910
dual Mike Singer350 amp alt
8 kinetic 2400 batteries two shuriken bt 120
1 kinetic 2000 under the hood
link to build log:
My link
I thought you knew everything? Just the other day you were throwing out the best brands etc, but you cannot set a filter? alright
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
I was tought it should be where box is tuned?
Sure, that should be a foolproof (fool's way) of setting the subsonic filter.
I'm pretty sure you can easily find how to do it properly.
Tip, it doesn't involve a secret formula or a rule of thumb, nor do you even need to know the exact tuning of the box.
Google is your friend
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
not sure what all the fuss is about.
i barely even have a subsonic level BUT i dont go full tilt when i know i am playing below box tuning.
how low do you play? i would set it around 23-27 htz. but it all depends on the box volume, tuning, and power.
i need more info to give you a better estimate.
edit: BUT
edit again: ok now that i understood myself and learned how to read properly, I see that you are tuned to 34 htz.
i would set your subsonic at half and call it a day.
and if you hear your subs bottoming out on lower notes raise the level more or dont play full tilt below box tuning.
fisigggg.JPEG?raw=1 Crossfire_Car_Audio2_265_zpsd219cf51.PNG ablogo_zps4c550ed1.PNG?raw=1 download%204_zpsecsgajxi.JPG?raw=1 Audison-Logo_zps3f7b2a7f.JPG?raw=1 sundown_bg2_zps1d0951fc.JPG?raw=1 orionsmalllogosig_zpsf8d08612.PNG?raw=1 KaptionLogo_zps06c2a555.JPG?raw=1
I RREEALLY ANGRY WIT U PHOTOBUCKET. HAD TO USE DROPBOX NOW HOLYYYYYY.
Wanna ride bikes?
Quote
On 9/16/2017 at 3:28 AM, Jake Pace said:
Oh i know how a 12v system works I did take 3 years of electronics in High school hands on and some in college and also worked on cars in college an always got A's to B's in each class.
But oh well enough dealing with ppl who have probably not even lived as long as ive been into electronics!
On 7/8/2013 at 4:01 AM, Banshee421 said:
Do horns get low
  • Who's Online   0 Members, 0 Anonymous, 586 Guests (See full list)
