How's my electrical?
my brother has a DC power alt 270a a deka under the hood and 2 kinetik hc2000 in the rear.. after i tuned his ride with the DD-1 he only dropped to 13.6 at idle and he is running a bc3500 so with this guy having d3100 he shouldnt be getting any drop unless he tuned wrong
i have a ampere 3800.1
dc 180 alt
1 deka 60 ah up front and 2 deka group 31 105 ah in the rear
2 runs of ofc pos and negative
did my big 3 with ofc sky high 2/0
never dip below 13.
try adding another run of wiring and is it cca or ofc?
gear in sig - minimal drop at idle full tilt. You should be good with a DC 5.0k + no clip on your electrical.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
you dont need a bigger alt to run 5k I ran 2 3500's @.5 in my subaru with a dc 230xp and 4 batteries. try adding a few more grounds. maybe one off the rear batts to the frame and another off front battery to frame. adding grounds always helps my voltage
*** SuperSeller Status Verified *** ( http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers/ )
"kevosinn's" astro van
8 custom Sundown Zv4 18's
4 Sundown scv 6000's
CNF Distribution CNC parts
Skyhigh wire
some batteries
SMD Meters and tools used on the install
http://www.stevemeadedesigns.com/board/topic/172877-kevosinns-vanwest-coast-skyhigh-car-audio-vehicle/
16,000 watt walled silverado build.
http://www.stevemeadedesigns.com/board/topic/161965-walled-silverado-4-hdc4-15s-4-crescendo-3500s-and-much-more/
8,000 watt 1999 Subaru legacy outback. Build log here: http://www.stevemead...ru/page__st__60
TEAM CNF Distribution
I was completly unaware that clipping caused voltage drops, I may need to have someone put a DD on my amp cause I really don't see any voltage drops BUT the song Make It Rain with Lil'Wayne and Fat Joe the beginning part that isn't even really bass it's more of a higher note actually it makes it almost look like I'm flashing my headlights at people.
200A alt from police Interceptor
1/0 Audio pipe wire
Interstate starter battery
Kinetik HC1200
Kinetik HC800
Powerbass Asa 1500.1 Dx
Orion HCCA 12.4
2003 Mercury Grand Marquis LS (CVB 25th Chapter)
Alpine Head Unit
stock 6x9's
Powerbass ASA 1500.1Dx
FC 1200 krank-it up battery
HC 800 Kinetik battery
Orion HCCA 12.4 in slot ported box wired down to 2 ohms
Audiopipe 1/0 gauge wire
Rockford fosgate ring terminals
Subscribe to the Youtube page
http://www.youtube.com/user/TManMusicPage
1/0 Audio pipe wire
Kinetik HC1200
Kinetik HC800
Orion HCCA 12.4
your clipping, dont ask me how i know. but your clipping.
1/0 Audio pipe wire
Kinetik HC1200
Kinetik HC800
Orion HCCA 12.4
Yes I find it weird it ONLY does it on THAT part of that song other then that no voltage drop, no dimming lights, nothing but i still turned the gain down a hair.
Alpine Head Unit
stock 6x9's
different frequencies makes the woofers impedance change. lower impedance = more power = more current drawn from electrical.
your amp can also clip at lets say 60hz but be fine at 30hz on X woofer.
  • Who's Online   0 Members, 0 Anonymous, 3465 Guests (See full list)
