hazestorm23 Posted December 26, 2013 Report Posted December 26, 2013 I was looking at amps and was just wondering why some amps doesn't have any fuses? you are supposed to use an inline fuse closest to the battery . Fusing rating depends on the amp itself
trisdog74 Posted December 26, 2013 Author Report Posted December 26, 2013 Ive always used inline fuses sounds crazy not to. I just thought it was a difference between amp without fuses and ones with.
Kyblack76 Posted December 26, 2013 Report Posted December 26, 2013 Edit - NVM ..lol SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
SnowDrifter Posted December 26, 2013 Report Posted December 26, 2013 I was looking at amps and was just wondering why some amps doesn't have any fuses? you are supposed to use an inline fuse closest to the battery . Fusing rating depends on the amp itself Fuse rating depends on the wire. You can always fuse less (2000 watt amp wired to 0 gauge fused at 200a) but you can never fuse more than the wire's rating. Don't put a 300a fuse on 4 gauge wire ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
hazestorm23 Posted December 26, 2013 Report Posted December 26, 2013 I was looking at amps and was just wondering why some amps doesn't have any fuses? you are supposed to use an inline fuse closest to the battery . Fusing rating depends on the amp itselfFuse rating depends on the wire. You can always fuse less (2000 watt amp wired to 0 gauge fused at 200a) but you can never fuse more than the wire's rating. Don't put a 300a fuse on 4 gauge wire true I forgot about that didn't know what wire he is running but I meant to get the amps full power considering he is running 0 gauge or what is best for his application
