(2) dual 2ohm to 2ohm impedence
Skax
My advice is take your ride to a professional. There is no shame in having someone do it for you. If that isn't something you want to do, find a forum member and get them to help you in person.
You just need to have both positives from the terminals wired together and connected to the amp. Same go for the negatives. You can do that by either running a jumper wire from one terminal to the other and then to the amp or just run a separate wire from each terminal to the amp. As long as both positives from the terminals are connected together and running to the amp and both negatives from the terminals are connected together and running to the amp you will achieve the goal of 2 ohms final impedance. Here is another diagram I found. http://a248.e.akamai.net/pix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/2DVC_2-ohm_mono.jpg
thats the diagram that confuses the hell out of me lol what i have now is a jumper on each sub from pos to neg and pos and neg ran from inside box to sub terminals and speaker wire from amp to box terminals which i guess is 4ohm load
2002 Mustang GT Procharged
Procharger P1SC Supercharger, 8psi
Procharger Intercooler, Headers,
Borla Off Road X-Pipe Exhaust, Mass Airflow
Upgraded Fuel Injectors
SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
If you have the subs wired like in the diagram it puts each sub to 4 ohms (subs to terminal). Then when you connect both positives on the terminals to the amp and both negatives on the terminals to the amp it gives you a final impedance of 2 ohms. Like CleanSierra said there is no shame in taking it to a professional shop if you don't understand. I would hate to see something bad happen if you don't fully understand.
would this work?
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
What amp are you running? If it is a mono block that will work fine.
1500bdcp fosgate
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Wire each woofer in series, then wire the pair in parallel.
Like this.
i guess my confusion is and a dumb one is the second sub doesnt have to be actually hooked up directly from the amp?so i will have one terminal on the back of the box with nothing in it??
Let's see if I can make it easier.
You wire each sub to 4ohm and then wire them together for 2ohm load to the amp.
1500bdcp fosgate
Yep the picture you posted will work just fine.
Like this.
wouldnt it work if i just did like i sketched though also?
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Where are you located at I'm sure any member nearby you wouldn't mind helping you out.
  • Who's Online   0 Members, 0 Anonymous, 6313 Guests (See full list)
