Take a AA or 9 volt battery and do a pop test. See if they are in phase. When you touch the positive and negative of the battery with the wires do all the speakers move the same way or does one go in and the other out? Also you mentioned that if you turn down the the frequency on the filter "it sounds like stock with that bass turned up", makes me wonder about the gain setting. The only other thing I can think of is dirty power, so maybe the signal coming in isn't clean or your amp just needs to be replaced. Assuming the speakers are in phase the next test I would do would is try a different amp.
I don't think its the speakers. Try giving them more power. My friend runs a pair of the pro 6x9's in his front doors and they are very loud. Idk I mean with as many speakers as you have you may need more power. How much do you have now?
No.
100W with only 1 speaker will ALWAYS be quieter then 100W and multiple speakers (unless you get cancellation).
  • Who's Online   1 Member, 0 Anonymous, 1477 Guests (See full list)
