bcbrassard Posted January 4, 2014 Report Posted January 4, 2014 http://www.ebay.com/itm/Lanzar-OPTI700X2-Optidrive-2800Watt-2-Channel-Competition-Class-Mosfet-Amplifier-/271258324958?pt=Car_Amplifiers&hash=item3f28418fde Ya even if it only does half of rated thats still 350 watts per ch. Better that you have now! ? I myself wouldnt buy crap but thats me!
pioneerforlife Posted January 4, 2014 Report Posted January 4, 2014 Looking at that amp, which is probly underrated and if you have it wired up correctly, your putting out 210 watts per ch bridged... so that would be like 52.5 watts to each speaker. Which isnt much be should be enough to get some sound out of them. but your 6.5s might be overpowering them. More watts man... more watts! not just that. he has his LPF at 230. those mids play higher frequencies than that. 2007 Ford Focus SES Hatchback Pioneer HU 4 Digital Designs 9515i's in a B pillar. 2 Soundstream XXX 15K's (running at 16 volts) Soundstream Mids/Highs in custom door panels (getting rebuilt soon) Soundstream TA2.160 and TA2.400 Sky High and KNU wiring 3 Banks of Maxwell caps Winston Lithium (not a fan) Bump4Life 250 Amp Alt. aka USAlternators Soundstream Focus and Avenger Build Log Instagram @p4linnovation YouTube: Team Blowin Loud
bassaddiction Posted January 4, 2014 Author Report Posted January 4, 2014 Looking at that amp, which is probly underrated and if you have it wired up correctly, your putting out 210 watts per ch bridged... so that would be like 52.5 watts to each speaker. Which isnt much be should be enough to get some sound out of them. but your 6.5s might be overpowering them. More watts man... more watts! not just that. he has his LPF at 230. those mids play higher frequencies than that. my bad i got low and hi fixed up hpf is at 230 meaning it doesn't play below 230?
bassaddiction Posted January 4, 2014 Author Report Posted January 4, 2014 i would put that opti on the 8s and the rf p850.4 on the 6.5
bassaddiction Posted January 4, 2014 Author Report Posted January 4, 2014 the rf amp i have now spec 100 W x 4 @ 4 Ohms RMS210 W x 4 @ 2 Ohms RMS425 W x 2 @ 4 Ohms bridged RMS High-Pass (HP): 40-400Hz 12dB/octave ButterworthLow-Pass (LP): 40-400Hz 12dB/octave Butterworth Tone controls Bass Control 0 to 18 dB @ 45 Hz Frequency response 20 to 20k Hz +/- .5 dB Dimensions 2.1 x 11 x 17.7 (in)
pioneerforlife Posted January 4, 2014 Report Posted January 4, 2014 Looking at that amp, which is probly underrated and if you have it wired up correctly, your putting out 210 watts per ch bridged... so that would be like 52.5 watts to each speaker. Which isnt much be should be enough to get some sound out of them. but your 6.5s might be overpowering them. More watts man... more watts! not just that. he has his LPF at 230. those mids play higher frequencies than that. my bad i got low and hi fixed up hpf is at 230 meaning it doesn't play below 230? correct. but usually people don't have it set that high. turn it down a bit and see how it sounds. 2007 Ford Focus SES Hatchback Pioneer HU 4 Digital Designs 9515i's in a B pillar. 2 Soundstream XXX 15K's (running at 16 volts) Soundstream Mids/Highs in custom door panels (getting rebuilt soon) Soundstream TA2.160 and TA2.400 Sky High and KNU wiring 3 Banks of Maxwell caps Winston Lithium (not a fan) Bump4Life 250 Amp Alt. aka USAlternators Soundstream Focus and Avenger Build Log Instagram @p4linnovation YouTube: Team Blowin Loud
bassaddiction Posted January 4, 2014 Author Report Posted January 4, 2014 Looking at that amp, which is probly underrated and if you have it wired up correctly, your putting out 210 watts per ch bridged... so that would be like 52.5 watts to each speaker. Which isnt much be should be enough to get some sound out of them. but your 6.5s might be overpowering them. More watts man... more watts! not just that. he has his LPF at 230. those mids play higher frequencies than that. my bad i got low and hi fixed up hpf is at 230 meaning it doesn't play below 230? correct. but usually people don't have it set that high. turn it down a bit and see how it sounds. like shit lol
pioneerforlife Posted January 4, 2014 Report Posted January 4, 2014 hmm. maybe it's the amp. do you have any other amp to test it on 2007 Ford Focus SES Hatchback Pioneer HU 4 Digital Designs 9515i's in a B pillar. 2 Soundstream XXX 15K's (running at 16 volts) Soundstream Mids/Highs in custom door panels (getting rebuilt soon) Soundstream TA2.160 and TA2.400 Sky High and KNU wiring 3 Banks of Maxwell caps Winston Lithium (not a fan) Bump4Life 250 Amp Alt. aka USAlternators Soundstream Focus and Avenger Build Log Instagram @p4linnovation YouTube: Team Blowin Loud
bassaddiction Posted January 4, 2014 Author Report Posted January 4, 2014 sounds like stock hu and speaker with bass all the way up
bassaddiction Posted January 4, 2014 Author Report Posted January 4, 2014 i got that small 4 channel amp thats on my 6.5s i was thinking about making it a 4 channel again and doing 2 ohms a channel with 2 8 each
