ThatGuyWithAJetta Posted January 8, 2014 Report Posted January 8, 2014 So i'm designing a box for a single e-15 for in the back of my 01 GMC Jimmy so here is the specs I came up with using Torres: Box dimensions: Height - 12 inches Depth - 20 inches Width - 36 inches Net Volume - 3.31 cubic feet Port dimensions: Height - 10.5 inches Width - 5 inches Length - 24 inches Port area per foot - 15.86 square inches Tuning - 36.27 hz configuration would be sub up port back to driver side. I want to keep everything under the cargo cover hence the reason why the box is so short. so anyone have any suggestions or changes i should make? !999.5 Volkswagen Jetta 1 Planet Audio BIg Bang 15 Powerbass 1500,1
boom50cal Posted January 8, 2014 Report Posted January 8, 2014 Add another baffle, wouldn't hurt. Just another 1/2 inch On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole.
Smoove Posted January 8, 2014 Report Posted January 8, 2014 I put you box and port deminsions in Torres. I am not getting the same tuning or net volume. How did you come up with your specs? 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/
TZspeakersZac Posted January 8, 2014 Report Posted January 8, 2014 Just make sure you brace it vertically (to secure that 20" x 36" panel) and it seems good to me. You may also benefit from rounding off the sharp edges on the port's opening. Nah man, it's cuz of the bass.
TZspeakersZac Posted January 8, 2014 Report Posted January 8, 2014 I put you box and port deminsions in Torres. I am not getting the same tuning or net volume. How did you come up with your specs? I just plugged it into torres as well and ended up with a net of 2.83 cubes. I then plugged that into winISD alpha, and ended up with a seriously jacked up frequency response curve for the E-15. The E-12 however looks solid. You're better off putting a smaller woofer in an appropriately sized box than a larger woofer in too small of a box. Though my previous post still applies. Nah man, it's cuz of the bass.
ThatGuyWithAJetta Posted January 8, 2014 Author Report Posted January 8, 2014 I put you box and port deminsions in Torres. I am not getting the same tuning or net volume. How did you come up with your specs? I put you box and port deminsions in Torres. I am not getting the same tuning or net volume. How did you come up with your specs? I just plugged it into torres as well and ended up with a net of 2.83 cubes. I then plugged that into winISD alpha, and ended up with a seriously jacked up frequency response curve for the E-15. The E-12 however looks solid. You're better off putting a smaller woofer in an appropriately sized box than a larger woofer in too small of a box. Though my previous post still applies. Sorry guys my bad depth was supposed to be 22 not 20 heres a screenshot in torres !999.5 Volkswagen Jetta 1 Planet Audio BIg Bang 15 Powerbass 1500,1
Smoove Posted January 8, 2014 Report Posted January 8, 2014 How much power are you planning on running 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/
ThatGuyWithAJetta Posted January 8, 2014 Author Report Posted January 8, 2014 probably 5-600 is what i was thinking, this is my first build so i'm not planning on going all out right off the back and pushing the thing to it limit !999.5 Volkswagen Jetta 1 Planet Audio BIg Bang 15 Powerbass 1500,1
Smoove Posted January 8, 2014 Report Posted January 8, 2014 Since you plan to keep the sub right at recommended. that a good idea. The E series is still an entry level sub which is why I personally would do about 13-13.5sqin per cube on the port. but thats just me. I know others will freak out about that number but it gives the sub a little more control. Again, thats just what I would do. 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/
ThatGuyWithAJetta Posted January 11, 2014 Author Report Posted January 11, 2014 sorry i didnt get back to you sooner internet was down for a couple days but how does this look? !999.5 Volkswagen Jetta 1 Planet Audio BIg Bang 15 Powerbass 1500,1
