XS Power
Right now the ground is in the rear on the trunk floor. has been sanded and everything. IDK what strut towers are so..... lol. Whats wrong with self taping screws btw? before i had the ground on some bolt sanded somewhere same thing idt its a ground issue. Hopefully tomorrow after work ill try to get you those readings.
The metal you're grounding to probably isn't very think. Which doesn't help a self tapping screw. This is how thick my truck spare tire area was made out of.
All that means is you need to use more self tapping screws!!!
1 self tapper in the center hole of the ring terminal then put a screw on each outter ends of the ring terminal so it doesnt wiggle back and forth!!
LOL
:Doh:
Snow has some good info OP. I strongly suggest listening to all he has to say or help with.
Dubindodge has an awesome example of why not to ground where you grounded...
And self tapping screws are not really a great grounding source.
Finally. The strut tower is that thing above the rear or front wheel with 3 or 4 bolts on top of it. It holds the springs and the shocks. Drill out a ring terminal so the hole is big enough. Sand down the area around one of those bolts really good. And ground using that.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Wait for it.... searching for strut tower pic in pb lol will be back with edit
Strut tower is good to ground to or go to the frame. (even though this is a unibody car I believe)
Like this
Edited by DubNDodge
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
Leave it to grant to have shameless plugs of his build log but still be helpful...
Good job sir.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
OP I understand why you did not want to attempt that but if you have a way to bore out the ring terminal to have a larger sized hole then that's best.
The strut tower is one of the best places for rear grounding and I myself saw over a 1.5volt difference in voltage drop switching my ground to mine.
Its a bit more work but it's all in the pursuit of doing this hobby correctly sir.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
I'll give that a shot. Will that mess with the springs or anything taking that bolt off? i have a 2012 car so im very careful when it comes to doing things. its a chrysler at that. should i leave my other ground the way i have it? amps ground to battery then battery ground to strut?
