voltage question.
You should not be smoking 0 gauge wire and a 300a fuse with just an 80a alt.
Where was the wire smoking/melting?
ok i have a question, this car has an 80 amp alternator. can i just hook straight up to the power distribution block under the hood where the stock wire was hooked up with a 100 amp fuse?
here is the power distribution blcok i was taking about
The nuts were loose on the 300 amp fuse holder, no question.
Just re-do the cable with a new fuse holder and make sure the set screws on the fuse holder are tight and you should have zero problems.
Or, just leave the stock wiring in place and remove the 1/0 gauge cable. 1/0 gauge cable is WAY overkill for a stock 80 amp alternator, and is probably not helping you at all.
  • Who's Online   0 Members, 0 Anonymous, 3249 Guests (See full list)
