what is a class j amp
hazestorm23
Read here to see what class j is http://ieeexplore.ieee.org/xpl/login.jsp?tp=&arnumber=5604342&url=http%3A%2F%2Fieeexplore.ieee.org%2Fxpls%2Fabs_all.jsp%3Farnumber%3D5604342
From what the article says class j is pretty efficient at low impedance. However a class d will be more efficient. The benefit of class j may be thd, other than that it appears to be inferior to class d for subwoofer purposes.
Also the article suggest that the class j amp described is used for microwave frequencies which are in the above 2 gigahertz range. That is way too high for audio so I'm not sure how this is optimized for use as an audio amplifier.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
I wouldn't worry about THD.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
Yeah that's some low tdh right thhur. Any damping factor on the info?
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
straight from the website. Turns out they made the same amp in class j and class d .
Damping Factor: >800
Earthquakes Class-J amplifiers deliver far beyond your expectations with blazing performance, intelligent design, and unique features that are second to none. These killer amplifiers operate in the range of 95% efficiency.
Heat sink designs, larger input and output terminals, and precise fine-tuning have put the reigning champions in an untouchable category. The heat sink evenly distributes heat from the amplifier so the amp stays extraordinarily efficient and cool.
Class J PowerHouse amps even have power connections 4-gauge and larger. All of these design features and improvements will dramatically increase presentation, output capabilities, sound quality, and your status in the winners circle.
Sold and priced per piece.
Specifications
Model nr.: PH-5000W-D1
EAN: 3-000668-975983
Class: "J"
Channels: 1 (Mono)
THD: >0.01%
Signal to Noise Ratio: >95dB below rated power
Max Power: 5000W
RMS Power 2-Ohm: 3000W
RMS Power 4-Ohm: 1500W
Okay now that you mentioned it is an earthquake amp we can stop wondering. They used to make a quality product but are way behind the times. They do not do close to rated power and boasting a crazy 95% efficiency they are flat out lying. Class j is not that efficient under perfect conditions. It will run hotter than class d and heat decreases efficiency.
1 XS Power D3100
Audio Control LC6i
Stock Deck
Wow, that's probably why. That is a high ass damping factor. And damping factor is most important at low frequencies so it's mostly needed in sub and midbass. Most amps I see dont even get higher than 400.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • Who's Online   0 Members, 0 Anonymous, 636 Guests (See full list)
