Shrinking volume advise TIA
Kyblack76
Before doing anything crazy we should talk
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
First talk to N8.
But if you wanted to put 2x's on the back wall, you could do it and where the port ends, or the visual portion anyway, do a 45* cut on them and stop them there. That way there are no sharp edges. Then if you need more, you could stack on top of those and then continue the 45* cut. So the second row would end at the short end of the 45* cut on the first row.
FYI, every foot of a 2 x 4 (1.5" x 3.5" x 12") is equal to .036 (or .04) cubic feet.
another thought, for only a little bit more work, is if you wanted to run 2x's all the way across into port view, you could cover it with 1/4" MDF and then caulk the corners and paint it. You'd never know the difference. Just a thought.
But I'm interested in N8's suggestions.
  • Who's Online   1 Member, 0 Anonymous, 1761 Guests (See full list)
