Skax Posted January 18, 2014 Report Posted January 18, 2014 Like a small high pitch squeal coming from sub any ideas ? 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
gally Posted January 18, 2014 Report Posted January 18, 2014 coil rub? 2010 Chevrolet Cruze Radio --- pioneer mvh-200vbt Front/back --- alpine type s 6.5" Sub Control --- Pac LC1 Sub Amp --- GZPA 1.4K Sub --- GZNW 15XSPL D1 Battery - GZBP 12.2500X
biscuitownz Posted January 18, 2014 Report Posted January 18, 2014 Does it happen when its not playing anything? If it does it's probably noise from the amp.
poorfish88 Posted January 18, 2014 Report Posted January 18, 2014 Is it alternator whine? Which is a pain in the ass to track down, but not impossible to fix.
Skax Posted January 18, 2014 Author Report Posted January 18, 2014 No idea but it sounds squealy when it beats idr if it does when it's down in heaadunit 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
Skax Posted January 18, 2014 Author Report Posted January 18, 2014 Bump any ideas ? 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
mmets Posted January 19, 2014 Report Posted January 19, 2014 Check to see if you get the sound when you turn the volume down on the head unit and when you rev your engine a bit. If you do it alt whine. Check to make sure you have a solid ground and also make sure you don't have any power or ground cables next to or touching speaker wires or rca's. http://www.stevemeadedesigns.com/board/topic/177477-slowboring-07-trailblazer-build/Pioneer DEH-80PRSPRV 8MR400-NDY (eight) PRV TW350Ti (6)Sky High 1/0 OFC, 12 gauge and 8 gaugeTM Metalworkz battery terminals 120 sqft HushmatXS Power D3100 (6)Singer 350 Amp Alt Singer 320 (2)American Bass SQL3200 JL Audio JX360/4 Crossfire XS 8K (2) DC Audio XL 15s (6)
alaskanzx5 Posted January 19, 2014 Report Posted January 19, 2014 push down on the sub and see if it rubs. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
smashedz28 Posted January 19, 2014 Report Posted January 19, 2014 Amp could be shitting out http://s691.photobucket.com/user/smashedz28/media/487694D3-1802-40B1-8A82-86014295CFB4-3498-0000023D2A268FDE.mp4.html
Guest Posted January 19, 2014 Report Posted January 19, 2014 push down on the sub and see if it rubs. on the center*
