The dumbest thing you've ever done while working on your vehicle?
Once I was installing my system back in my car and I had wired the amp and rear fuse before I put it in. When I finished I connected the main wire to the battery and got a big spark. I thought it was because of the fuse so I removed it and connected the wire before the fuse and when I inserted the fuse it started to arc like crazy and It lasted for a couple of seconds. I finally removed the fuse and some of it melted. When I checked the amp I had positive and ground mixed up. Luckily none of my equipment got damaged or the car got burned.
I also left a 5 lb hammer in a box once. Didn't find it til i pulled the woofers to sell
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I sneezed while holding my in dash nav and dropped it on the shifter. Nice big slice in the screen........ No bueno.
2012 EvoX with the only INEZ928hd dash mod in the world!!!!
Oh God, where to start. I've pierced my gas line. I've pulled a bare power terminal through the firewall with a fuse in and the car on. I've arched a battery with a wrench. I've connected ground to power and power to ground. I've wired to a 0.5 ohm. LOL. ETC....
I blame most of my mess-ups to alcohol and marijuana though, and the occasional bit of frustration that gets to me.
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
Yesterday I put subs in and I hooked up the amp and drilled the subs in, went up front to turn the car on to see if the subs were working and when I turned the pac lc1 up I got nothing so I'm like wtf... I forgot to wire the subs lol I do little shit like that everyday but I haven't had anything crazy happen yet
2006 Ford Explorer
2 Team AA/Sundown 15s
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
Forgot to completely tighten my hot wire to my battery post and my car shut down on the highway and the lug melted in half. I also watched my brother go through a pack of fuses as he was determined he was wiring things right, but he was doing it backwards lol.
Left my soldering iron on the other day when it was getting dark. Went to sit down on the concrete and didn't realize where I had left it… All my body weight that was on one hand transferred to the end of a soldering iron… yeah that didn't feel good.
How it looked right after I burned it:
How it looked 30 minutes later:
09 Challenger R/T (Audio system under construction):
  • Pioneer AVH-X4500BT (PAC RP4CH11 harness)
  • (2) Sundown Audio SA-8v2 (inverted)
  • CT Sounds AT1400.1D
  • XS Power D3400
  • 40 sq ft. Audiotechnix deadener
  • 1/0 Audiotechnix wiring
  • stock Boston Acoustic 7 speaker amplified system (for now)
  • Sealed trunk enclosure
Build log:
http://www.stevemeadedesigns.com/board/topic/178399-slammed-dodge-challenger-sundownct-sounds-build/
TEAM GOAT
About 280 full moons ago/1990-ish) i got tired of my 1980 toyota
20R truck always blowing the fuses under the dash,so what was a 18yr old to do? Roll the blown fuses up in tin foil and pop 'em back in there!!..needless to say,fast forward a month i had no electrical use of anything including no no wipers/dash lights heater accec etc.
Not me personally, because I have always thought people are complete idiots to be crawling under a vehicle with no jackstands under it and only raised up due to the hydraulics, but watched a local dude who is full of himself crawl under his hopper and the hose in the rear blew.....whole cars weight came falling down on his chest. He ended up in the hospital for a few days. A lot of weight landing on your chest....no thank you.
see thats what i love about the under car maintenance with hydros just lock that bitch up throw the stands under it and tap the switch a few times to dump it lol
b8426b6f-6b19-45b2-aa60-f898a05a3587_zps
88 ranger xlt ext cab
HU. jvc bluetooth/usb deck
mids/highs. 2 earthquake 5s. 2 earthquake 6s and 2 Cadence CVLT-60 tweets
subs. 2 Addictive audio V4 12s
SAZ3000D
SAX100.2
alt. 135 amp ford mustang
batt. deka G31 1131MF
box. 4 cubes 30-34hz
rims. black 13x7 100 spokes with chrome knock offs.
tires. 155/80r13.milestar touring se
real billet grille not a bolt on.
HYDROS FINISHED!!!!! 2 pumps 4 batts
I get fucked by this old guy at work all the time. MY ASS WILL FOREVER REPRODUCE THE LOWEST AUDIBLE SUB BASS FREQUENCIES KNOWN TO MAN!
just because we think it ugly and it sounds like a bucket of smashed assholes.
Hanes. And dried jizz. It's better than fatmat
