S10 Blow Through?
well wont be starting it for a bit I was thinking about running 4 larger subs.
what do you think i could fit in the bed of an S10 in a blow through?
a blow through is just basically the box in the bed and the port coming into the cab?
think i could fit 4 18's? if not 4 15's? i was just thinking something around 4 18-15" BL's or Q's on a Rockford T4000.1
think it could bassrace a 150?
i know nothing about these so help me out!!
15" LMS Ultra
AB VFL 200.1 3kw+ rms@ 1 ohm <-- 500.1 in near furture
3.5 cubes at 34 hertz
2 Exide Orbital's
200 Amp EA Alt
125 sq ft BXT
ok, look at chodes blow thru, i kno his truck is bigger than urs, by a good amount, but that guy has skillz... so u could look at this build and take some notes.... i dont see why u couldnt bassrace 150 anything is possible... u can take notes from kingsuv too, he did a blowthru and that thing sounds clean and gets down
My F-150 Build
GET ON THE BANDWAGON
what if they tried messing with the amps when the subs werent louder :ehh: hahah jk :pardon:
cool ill look into it
15" LMS Ultra
2 Exide Orbital's
200 Amp EA Alt
125 sq ft BXT
depends on your blowthrough. is iit a full blow through window and cab or just a blow through below the window?
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • 1 month later...
First bed cut in my truck (f150) i had 2.5 feet of bed left behind the box and it was 8 12's so if you can sacrifice your bed 4 18's will fit. Maybe put extra batteries under the bed floor in a custom rack to get even more room.
2003 Ford F-150 Reg Cab layin body on 26's
2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine.
2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's
2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
  • Who's Online   0 Members, 0 Anonymous, 2309 Guests (See full list)
