Well since I can't even get a signal to begin with, I'm suspecting a bad ground. How would you properly ground a probe to your amp? n00b question but hey this is my first time doing something like this.
If you're trying to measure at the amplifier's speaker outputs and you get no signal, probe the negative speaker output. If you're trying to test line level outs from the head unit, make sure your RCA is making a ground connection to the meter & remove any isolation transformers (noise blockers). If you're using an LOC, you aren't likely to ever see a signal light flash but that doesn't mean the distortion light won't fire.
Facebook: facebook.com/audioanarchyllc
Instagram: audioanarchyllc
Youtube: youtube.com/bbeljefe
Seriously you can't figure out how to ground a probe? Stick it in the wire or stick it in the ground input
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
My DD-1 and CC-1 came with the same leads . Alligator clip ground and no extra adapter .
Exactly for me too, CC-1 and DD-1 both had the alligator clip and no extra little attachment thingy, but mine both came with white disks
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Hey OP, quick question. I know you said you're having a hard time getting a signal at all from the HU. Are you running a ground loop isolator? If you are, that could be your problem and why you're not getting a signal.
Not running a ground loop isolator. Just a cheap RCA cable. I finally got a signal after tinkering it around for a bit. But I had to turn my HU waaaaaaaay up to get it, like volume 20 out of 35 to see the 40Hz detect light up. With my HU set to everything flat, I maxed out my amp gain and volume at the same time and got no distortion (weak signal?)
My 1KHz detect, however... never came up. Refused to detect that part regardless.
Could it be a bad RCA?
“The fascination of flight can't be expressed with words. But it really lies beyond the capabilities of human endeavor. Once you've experienced it, you'll never be able to forget it.” - Friedrich Oblessor
Both my dd-1 and cc-1 came with the harness you got.
No alligator clip. Works for me, just probe the wires or tighten the terminals onto the probe.
I also didn't get the circled piece.
I think it allows you to plug rca's directly into the dd1 cc1?
Yea found my 40Hz signal, but 1KHz signal still remains a mystery lol
Are you trying to test the 1khz through the sub output?
I don't think your deck will put out that frequency through the sub. At least mine doesn't.
