Dual 12's or single 15 for daily groundpounder
lilman
Ok thanks and I'm thinking maybe a Crescendo BC3500D
sweet amp.
covered under warranty at .5 ohm
rated for 3800+ at 13 something volts.. great amplifier
Build's consist of:
2004 Chevy Impala :
Pioneer--------------------- DEH-X8600bs Soundqubed/AQ------ Q4-120
Rockford Fosgate---- Punch-500.4
Soundqubed/AQ----- Q1-3500D.1 Alpine----------------- 6.5's & 6x9's
Subs: TBA All Knukonceptz and SHCA wire and rca's
Home Music Setup
(4) Soundqubed HDS200 15's in two separate 15.5 cubic foot enclosures tuned to 31 hrz --- XM radio hardwire
Updates coming all the time on both builds
n8ball2013
"bullshit. Everything fits. If you cut enough."
what vehicle is it?
Build's consist of:
2004 Chevy Impala :
Home Music Setup
n8ball2013
I would definitely do two 12's over a single 15. A single 15 is all i can fit lol. so if i had the space for two 12's i would go for it. You may probably end up with more power with two 12's anyway. However,dont forget bigger woofers = higher sensitivity
Depends on the woofer. The XCONs have better sensitivity than the Sundown even though they are 12s and the Sundown 15.
I think that I would go with the 15 because its cheaper and would be plenty loud. Also I like the look of the Sundown. If you are running 3800 watts I would probably go with the two 12s, better power handling. Flip a coin and go with it, you will be happy. I mean what sort of bass are you used to having. Have you ever heard a Sundown Zv4 or an XCON. If not you will be blown away no matter which one you choose.
Depending on the app, if you just want low & loud.. One 15 would do the trick, I didn't research their prices, but I figure that the sundown 15 setup will be cheaper and require less power.. It will get you what you need, and drop some jaws in the process..
  • Who's Online   1 Member, 0 Anonymous, 942 Guests (See full list)
