zanekeimigdesigns Posted February 4, 2014 Report Posted February 4, 2014 Hey guys I have couple of questions about midrange sound. I have had some systems with subs and compenent speakers but to me all of my setups lack the quick midrange punch to fill in between my highs and my subs. For instance in my camaro I have an amped 6.5 component set in pods in my doors and amped coax 6x9 in the rear seat area and a ported twelve in the back. It sounds okay but there is something missing somewhere between the 6.5's and the sub. Hopefully I don't sound stupid. If anyone has any input thanks in advance.
BoomZoom808 Posted February 4, 2014 Report Posted February 4, 2014 What are your x-overs set at? That can play a major part before swapping components or upgrading. Also sealing off and deadening helps a lot 2010 Mazda 3s 2.5L Pioneer DEH-X9600BHS Knu OFC 1/0 SS Platinum AGM / XS Power XP750 Alpine PDX F-4 / Morel Maximo 5 + Coax 5 IA 10.1 / SSA XCON 12
Kyblack76 Posted February 4, 2014 Report Posted February 4, 2014 Any dampener on the doors? like, 70% plus coverage? Or just toss em in and go? SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Kevin M Posted February 5, 2014 Report Posted February 5, 2014 In for answer on crossover points and sound deadening. It sounds like what you are missing is midbass. It is hard to get it right in a car. Those 6x9's should be doing work in that department though. 2005 Ford Focus zx4 AMT's and Planars 18" Infinite baffle
zanekeimigdesigns Posted February 5, 2014 Author Report Posted February 5, 2014 Any dampener on the doors? like, 70% plus coverage? Or just toss em in and go? Yes the entire car is done inside the doors in the pods in the quarters where the 6x9s set in...
zanekeimigdesigns Posted February 5, 2014 Author Report Posted February 5, 2014 What are your x-overs set at? That can play a major part before swapping components or upgrading. Also sealing off and deadening helps a lot I have messed with the x-overs quite a bit I'll post up what they are exactly tomorrow.
alaskanzx5 Posted February 5, 2014 Report Posted February 5, 2014 What speakers do you have? Maybe they just can't play the lower freqs. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
zanekeimigdesigns Posted February 5, 2014 Author Report Posted February 5, 2014 What speakers do you have? Maybe they just can't play the lower freqs. I have dd audio cs 6.5 component sets in the doors and the dd audio coaxial 6x9's in the rear quarters area
alaskanzx5 Posted February 5, 2014 Report Posted February 5, 2014 Don't know anything about them. What's the freq range on them? t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
zanekeimigdesigns Posted February 5, 2014 Author Report Posted February 5, 2014 Don't know anything about them. What's the freq range on them? Crossover Frequency 4kHz - 12 dB/Oct Frequency Response 40Hz - 25kHz this is the component set Frequency Response 40Hz-25kHz this is the 6x9
