Subwoofers not as loud as they should be?
mmotux
If you don't have cash for a new amp to actually run the subs at their suggested wattage, you're stuck with what you Have currently. What amp does your friend have in his truck?
Not sure. It's a memphis audio amp though
you are unable to use any of the amps you have. they're all 4 channels or two channels. 4 channels are made for door speakers.
you can use a 2 channel on two woofers, but you have the wrong voice coil configuration on the woofers so it wont work.
you could get 20-50 per amp you have, giving you 60-150 for an amp. craigslist will be your friend.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Hey man, just ran across this. I'm doing a budget build for one of my interns and he's really strapped. This amp may be perfect for you if you need 600wrms @ 2ohms:
http://www.amazon.com/Soundstream-RUB1-700-1x400-Block-Amplifier/dp/B0023VMJ12/ref=sr_1_1?ie=UTF8&qid=1391892113&sr=8-1&keywords=soundstream+rubicon+1.700
This is a discontinued amp from soundstream, but specs can be found here:
http://www.sonicelectronix.com/item_23983_Soundstream-RUB1.700.html
I don't think it'll be as pictured, looks like they have a 4ch pictured, and the 1x400 in the heading is the rated power @4ohms. In the details of the description, it states it's a 1.700.
Hope this helps, hope you get those subs slammin on a better amp soon.
  • Who's Online   0 Members, 0 Anonymous, 679 Guests (See full list)
