HELP PLEASE!!!! ODD PROBLEM OCCURES!!
So I have two 15" DC subs in a 4th order on a DD M2b with Stinger ALternater under hood. I'm running on 14 volts with a rear battery on amp. I've done replaced amp, RCA's, and all wires. Still nothing. Most often I press my gas pedal and amp goes into protect mode. And when I turn my bass knob up half way amp goes into protect??? Subs wired to 2 ohms. In my old vehical I had everything at .7 and had no heating or anything bad. Please help. No one can solve my problem. Subs are good and coils are brand new.on regular 12 volt power I don't have the issue.
Either a bad ground.
Or amps bad
99 expedition
Two 15 inch dc audio xls
Ported box tunned to 34 hrtz
Soundstream pcx.2000d(better amp soon)
0 gauge
big three(soon)
Yellow top,(more batts soon)
Do you have a voltmeter in the vehicle ?
It's not the amp it's the install. You're sending too much voltage to it and it protects. Be glad it didn't poof
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Maybe gains turned up too much?
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
Alt could have a bad regulator would be my 1st guess
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 3129 Guests (See full list)
