Running my amp at lower impedance than it's meant for?
chrisw.
I'll tell you right now those old thunder amps will just nuke themselves they do not protect. I owned like 5 of them. If you aren't prepared to replace it then I'd stop fucking around with it
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
My protects all the time when I push it
Still Living in the 90's
MTX Thunder 2300x
MTX Thunder 2150x
MTX Thunder 275x
MTX Thunder 1500dx <---still searching
It thermal protects because it gets hot. When it pops and you come back in and saw ok it blew I'm going to be the first one in line to say I told you so. I'm not sure what amp you have but I'm guessing it's a thunder 301. It should be 2 ohm stable. The two channels are not two ohm mono stable. Now as hot as it gets at rated impedance imagine under. It's also not doing 1k either. They would do about 75 over rated.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Your guess is wrong. It's a 2150x (see sig) and if you read the original post you'd see that we clamp tested it so I know exactly how much power it's pushing.
It did 518w @4ohms and 983w @2ohms 13.9 volts. I'm not disagreeing with you that it may blow running it at 2ohms so no need for I told you so's or for that attitude. All I said is it thermal protects all the time when pushed hard @ 4ohms and it's not thermal protecting @2ohm cause I'm not pushing it hard
MTX Thunder 2300x
MTX Thunder 2150x
MTX Thunder 275x
Clamp tested how?
MY BUILD *****http://tinyurl.com/gmcbuild*****
Vehicles
2005 GMC Canyon
CB1000r - Currently where any future funds are going. (exhasut,bazzaz, ohlins shock, screen, etc.)
crf250r - Used to be race bike..now I just trail ride..practice at the track on it.
CH80 - Daily beater (when nice weather)best 150$ ever spent. 100+mpg
Sold to:
Skullz - pstone11 - Leo1103 - Volvo 63' - pavelpardo - imnew59585
Shower farts still piss me off.
I think theyre pretty neat. When the water runs down your crack as you let one out... its like shitting in a crockpot.
did you use an oscilloscope or dd-1 when clamping? if not, you're probably clipping the amp to get those numbers.
and yes amps can literally catch on fire. my audiopipe did that.
  • Who's Online   0 Members, 0 Anonymous, 406 Guests (See full list)
