ROLEXrifleman Posted February 10, 2014 Report Posted February 10, 2014 Since we are running with numbers my Fosgate does 165% over rated. There's even video I win the interwebz Rolex you sicken me. Just let me finish my pie ~ Juice
Guest Posted February 10, 2014 Report Posted February 10, 2014 distortion/clipping = higher numbers. simply put if you literally did not have an oscilloscope or dd-1, you have absolutely no idea if the signal you were clamping/metering was clean. yeah i can probably get 2000w out of my audioque 1200, but it wont be clean.
n8ball2013 Posted February 10, 2014 Report Posted February 10, 2014 Ok since you avoided my question bow does an amp fused at 60 amps of class ab technology make 1k THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
chrisw. Posted February 10, 2014 Author Report Posted February 10, 2014 I'm still confused about the part where I was not accepting the answer? I asked the question, saw some videos of amps going up in fire and decided (and stated) that it wasn't worth the risk to me. A few of you are so desperate to make this something it not lol. Still Living in the 90's MTX Thunder 2300x MTX Thunder 2150x MTX Thunder 275x MTX Thunder 1500dx <---still searching
n8ball2013 Posted February 10, 2014 Report Posted February 10, 2014 Not really just pointing out the bs THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
CleanSierra Posted February 10, 2014 Report Posted February 10, 2014 N8 is such a meanie Im not the one you want to try to troll. Just a fyi for you.
chrisw. Posted February 10, 2014 Author Report Posted February 10, 2014 We did our test. Those were our results. Whether or not anyone here believes them to be accurate is another thing but they seem consistent with the reputation of these amp. And FWIW my only reason for even mentioning the clamp test was not to brag. 1000w isn't that big a deal, but rather to explain my temptation to run the amp @ 2ohms. If I knew it'd give some of you a debate boner I would've never brought it up. Still Living in the 90's MTX Thunder 2300x MTX Thunder 2150x MTX Thunder 275x MTX Thunder 1500dx <---still searching
boom50cal Posted February 10, 2014 Report Posted February 10, 2014 Since we are running with numbers my Fosgate does 165% over rated. There's even video I win the interwebz Rolex got the biggest e-peen of the day today back to topic, didn't read the second page, didn't need to. OP, if you don't want to call the fire department in the near future, set the amp at 4 ohms WHERE IT IS DESIGNED TO BE and call it a day. Losing a car in a fire fucking sucks. On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole.
Guest Posted February 10, 2014 Report Posted February 10, 2014 3rd time i said this. no oscope or dd-1 = invalid results. no oscope or dd-1 = easy to clip while clamping. clipping = false numbers.
mnrookie Posted February 11, 2014 Report Posted February 11, 2014 So you clamped it doing 983 watts at 2 ohms? That means you were running at or close to 1 ohms nominal, .5 ohm per channel. Sounds like you went wayyy below manufacturers recommendations.
