installing stinger voltmeter into dash?
Skax
Looks like you have a retarded half functioning cop car in your truck, especially if it's up high lol.
I mean half retarded as only one color is there
make sure you place this gauge in a EASY to REMOVE location for easy access to replace it. Do not forget to set the gauge with a real volt meter as well, as it does not come even close to accurate out of the box (or atleast the 64 i went thru didnt)
I thought your name was Don Draper... I've been watching too much Mad Men xD. But ^^ is important, with the stingers you get to calibrate them which is nice.
Welcome to my sig :D
My build on my 2008 Jeep Grand Cherokee Laredo 4x4:
2 Sundown SA 12's
Sundown SAZ 1500d v3
Alpine CDE-HD148BT
Hertz 165 Speakers
Atrend Carbon Enclosure
Stinger SPP925 Battery
Sky High 2/0 & 1/0 Power Wire & Big 3
:domodance::domodance: Legal 145.2 dB. :morepower1: Team Sundown. :domodance::domodance:
cd64929e-8a60-41ea-b784-c5c6096f49b8_zps
so run it with some 14ga speaker wire?
2002 Mustang GT Procharged
Procharger P1SC Supercharger, 8psi
Procharger Intercooler, Headers,
Borla Off Road X-Pipe Exhaust, Mass Airflow
Upgraded Fuel Injectors
SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
If your intent is to monitor the voltage at your subwoofer amp you need to have the power input for the meter wired directly from the subwoofer amp's terminal. If you only care about general system voltage then you can get the signal from the head unit.
I'd really like to know:
Does it make a difference if the positive is on the amp but it's grounded at the headunit?.....Does the + and - need to be on the amp or just the + ?
To get the most accurate reading possible at the amp with a DMM, you would probe the positive and negative amp terminals. You should do the same with a permanently installed voltmeter. And I would run a wire that's a bit larger than necessary in order to eliminate the possibility of voltage drop in my test wire.
Facebook: facebook.com/audioanarchyllc
Instagram: audioanarchyllc
Youtube: youtube.com/bbeljefe
how do you go about probing the positive and negative terminals and what size speaker wire would you recommend?
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
I just bought the Stinger SVMB Blue voltage display so I will be doing the same thing.
"Toyota Camry rebuild page 21 (link)http://www.stevemeadedesigns.com/board/topic/183768-94-crossfire-camry-18s-walled-singer-alt-has-arrived-rebuild-starts-pg-10/page-21
PIONEER DEH-P8400BH
2 CROSSFIRE C5 1700D
2 CROSSFIRE C7 18
HOOD. NSB GROUP48 TRUNK SMS AGM400
DUAL RUNS X SCORP 1/0 OFC
275A SINGER ALT.
DYNAMAT XTREME
SOUNDSTREAM TA4.280
PIONEER COMPONENTS
Im questioning this.... I would think the headunit and amp will see different voltages... I would think you want to monitor your voltage on your amp. So that being said don't you want to wire it to the voltage your amp is seeing?
PIONEER DEH-P8400BH
2 CROSSFIRE C7 18
275A SINGER ALT.
DYNAMAT XTREME
SOUNDSTREAM TA4.280
PIONEER COMPONENTS
  • Who's Online   0 Members, 0 Anonymous, 719 Guests (See full list)
