CleanSierra Posted February 19, 2014 Report Posted February 19, 2014 Here you go:I was able to get 33 Hz tuning. It's way under the port area that is ideal, but it should work without noise. I'd round over the port and inside and out with a 3/4" roundover on a router. It's 135" of port which is 67.5" per sub. Tuning is 33 Hz and internal volume is 8 cubes. If e go closer to the 10 cubes side, more port area can be had since the volume will allow that with the tuning. I have a double baffle included.Dimensions are listed in the Sketch but the port is 4.5" by 30" wide and is 21" deep physically. SO you would have a 3 pieces. 2 pieces that are 5.25" by 21" and the big port top is 30" by 21". You can also choose to take .75" off of each if you want them completely inside of the box. The outside dimensions areWidth - 40"Depth - 26"Height- 24"Port - 30X4.5" Edit- That will be $5.00 Im not the one you want to try to troll. Just a fyi for you.
elflako17 Posted February 19, 2014 Report Posted February 19, 2014 ^^^^ his designs work pretty damm good 2010 Mazda 3 *Rebuild Time* Subs - (2) AA Mayhems 12's Sub amp - (1) Populus Audio TPA 6500 Headunit - Pioneer App Radio 2 Batteries - XS Power (1) D3100 up front | 6 XP950 rear Wire - Sky High 1/0 Gauge wires and RCA's and steve's VM1 Alternator - Singer 260 Externally Regulated Front Stage: (2) PRV Audio 10W650A (4) PRV Audio 8MR500-PhP-4 (4) DS Bullet Tweets | (2) 6.5 Components (Rear doors) Mids & high Amp : (2) Populus Audio 100.4 Processor: Rockford 3sixty.3 The Build Log : http://www.stevemeadedesigns.com/board/topic/175922-2010-mazda-3-2-aa-mayhems-12-pg14-new-video/page-11
CleanSierra Posted February 19, 2014 Report Posted February 19, 2014 ^^^^ his designs work pretty damm good Haha, I would do your box much different now than last time. You're into the big boy stuff note though. You liking your new setup that Dre hooked up? That guy does some work dude, love it. Im not the one you want to try to troll. Just a fyi for you.
elflako17 Posted February 19, 2014 Report Posted February 19, 2014 well talking about new set up this coming week is going down lol, new alt , more batts new subs going in 2010 Mazda 3 *Rebuild Time* Subs - (2) AA Mayhems 12's Sub amp - (1) Populus Audio TPA 6500 Headunit - Pioneer App Radio 2 Batteries - XS Power (1) D3100 up front | 6 XP950 rear Wire - Sky High 1/0 Gauge wires and RCA's and steve's VM1 Alternator - Singer 260 Externally Regulated Front Stage: (2) PRV Audio 10W650A (4) PRV Audio 8MR500-PhP-4 (4) DS Bullet Tweets | (2) 6.5 Components (Rear doors) Mids & high Amp : (2) Populus Audio 100.4 Processor: Rockford 3sixty.3 The Build Log : http://www.stevemeadedesigns.com/board/topic/175922-2010-mazda-3-2-aa-mayhems-12-pg14-new-video/page-11
evermaxx Posted February 19, 2014 Author Report Posted February 19, 2014 So will the X still shine on this box design? Team Subsonic Lows Get your garbage EMF products of my amp bitch Man....it makes a nice work bench
evermaxx Posted February 19, 2014 Author Report Posted February 19, 2014 Can I get lower by porting with aero ports? Team Subsonic Lows Get your garbage EMF products of my amp bitch Man....it makes a nice work bench
CleanSierra Posted February 19, 2014 Report Posted February 19, 2014 I'm sure the X would sound just fine in that box. It's about what anyone else would run for port area on a 15" sub. Im not the one you want to try to troll. Just a fyi for you.
CleanSierra Posted February 19, 2014 Report Posted February 19, 2014 I'll check on aero ports later Im not the one you want to try to troll. Just a fyi for you.
evermaxx Posted February 19, 2014 Author Report Posted February 19, 2014 alright, thanks. Team Subsonic Lows Get your garbage EMF products of my amp bitch Man....it makes a nice work bench
evermaxx Posted February 19, 2014 Author Report Posted February 19, 2014 Lemme see if I can pull some more depth off.. Since I finally got my amps i'll do a cardboard dummy of the box and see what I can do. I'm pretty sure I can get away with another 2 inches of so with depth.. Really don't want to go any higher. I now I MAY be able to squeeze another inch out of width. Team Subsonic Lows Get your garbage EMF products of my amp bitch Man....it makes a nice work bench
