DC Sound Lab
DC Audio 3.5k Dyno Testing using Single and Dual Inputs
That was cool to watch. I have a set of toolmaker 1/0 to 4 reducers I was going to use on my amp but then found out that 1/0 wire fits. I guess I will break them out and install them on the end of my power and ground.
Thanks for the vid.
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
awesome video cody. I noticed about a .4 ish voltage gain with my dual inputs using way less sophisticated equipment.. But just tossing that in there to say that i did see and hear an improvement.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Well that was an informative test. For the record I never said dual inputs were crap, but always wondered about the contact area. And now we have some definitive data.. which is nice.
Its odd that the 1 to 1 connectors are quite a bit better. Alot more than 2w difference. In fact its more power less drop all with less current draw as well which mean higher efficiency. . Which is a big deal.
With some practice you can easilly get bare wire to look perfect, but it is annoying. For my money for looks oalone its not worth it, but for the results you recorded it absolutely is.
Ive been on the fringe of ordering a set of these for the longest time, but didnt wanna waste my money. I saw this thread and got excited to finally know the truth..
Thanks for the info.
Setup:
2010 Hyundai Elantra
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
DD M3b and 2 12" AQ HDC4s
  • Who's Online   0 Members, 0 Anonymous, 1398 Guests (See full list)
