d3100 OR 100' 1/0 spool for multiples runs
What??? My d3400 and my 136a alt pulls like 440 at 11v... now not for very long.. and idk what his amps are but you gotta figure the alt is 270a, any quality battery will be able to put out 200a for a lil bit. Certainty a d3100..
Its not like hes gonna melt the wire, but one run of wire wont cut it imo... I mean hell the alt alone will max the current carrying capacity of most 1/0 wire. And any current pulled from the front bat is then bottle necked..
Im not saying he needs 6 runs so buy 100ft of wire. But if he only has 1, hes gonna need more. 2 at least. Hes wanting to add a 3rd d3100 chances are hes gonna pull some power...
Id get that bat. And 50ft of wire if you need it.
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
Lots of folks look at the rated wire ampacity and stop at that.
Really, you need to dig deeper. Look at your voltage drop across the wire
Right.. of course current capacity depends on length alooooot. My point being hes def gonna pull his 270a, if he didnt he wouldnt even get into his battery reserve and wouldn't be looking for another 3100.
We really just need more info.
My first thought was whos daily driver has 120 plus ft of 1/0 power wire??
Setup:
Xs D3400/ Xs XP3000
I have about 80 in mine :shrug:
45ft front-back and alt to battery runs
15ft in misc grounds
20 ft for amp wiring
Adds up fast lol
Lol I spelled out power wire because I meant power wire. This guy wants 120 plus ft of power only wire...
And yes I realize current flows through the negative I was jusy keeping it simple.
120ft of posi wire.. lol that's alot. I figured he was using frame for return path..
Setup:
Xs D3400/ Xs XP3000
And I think here is where we need to stop and wait for OP to respond ;)
Yea I just get bored and stuff..
Setup:
Xs D3400/ Xs XP3000
Im running mojo 4kw at 0.5ohm, no mids or high amps. I'd say about 500amps current draw. The voltage went from 14.4v to 13.0v at full tilt driving, idle would drop to low 12's. Idle is the problem. Amp pull so much current draw at idle. I have only one run pos/neg all around.
I'd like to keep above 14v while driving, not 13.0. Would add a d3100 help voltage up?
Right now im leaning toward to d3100 after read your inputs.
'91 Honda crx - TOTALLED
200amps rebuilt Iraggi alt
2 d3100
Mojo [email protected]
2 15's DC XLm1 in 7.2cubes, 2 6" aeroports tuned to 32hz
Another d3100 will give you more reserve. Which will help you keep the voltage longer..
But imo you would also benefit from another run of power wire to the back.. your situation is like trying to suck a pineapple through a straw..
Setup:
Xs D3400/ Xs XP3000
With that amp and that load I'd want both. I'm surprised it doesn't smoke to be honest
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 2361 Guests (See full list)
