Bought new calipers and new master cylinder because I had a lockin brakes issue now I have no brakes the system doesn't want to bleed what should I do?
2004 trailblazer
4 FI BTL 18s
(2) DC 10.0k
xs power d3100s
mechman 270
158.2 @41
Bad brake lines if you cannot get them to bleed, the inner tubing must be collapsed not allowing the fluid to pass through.
Either you can replace them with OEM or get the better stainless steel versions which will give a much better feel to them.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
Here's the thing the rear brakes were holding before I changed everthing now nothing is holding, the back ones were functional before I changed the cylinder
2004 trailblazer
4 FI BTL 18s
(2) DC 10.0k
xs power d3100s
mechman 270
158.2 @41
2004 trailblazer
4 FI BTL 18s
(2) DC 10.0k
xs power d3100s
mechman 270
158.2 @41
Did you get the same master cylinder cause it sounds as if it may be different and something isn't quite right or it is bad and needs to get replaced.
Try the old master cylinder and see what happens if you still have it on hand.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Did you follow the proper bleeding sequence?
Did you bench bleed the Master Cylinder before putting it on the car?
Was going to ask the same thing myself
Just throw it in park
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 1665 Guests (See full list)
