33hz Posted February 17, 2014 Report Posted February 17, 2014 So I'm sure I'm not the only one to notice this but I've noticed this pattern with cheaper amps. It seems with all variable being equal, same car, same sub/enclosure, same tune on the amp, budget amps don't seem to have the same sound quality in the lower frequencies. I have a kicker amp on my subs, a few friends have fosgate and JL and a few other friends have audiopipe, hifonics and JBL. We know how to tune amps but there is a clear difference between them that tuning doesn't seem to change. It's not that the lows aren't there, it just seem they don't hit with same authority. Anyway I'm not having this issue with my set up just kind of curious why this is and what can be done for those with the cheaper amps. Would an independent crossover help this? The thing is boosted music still slams lows on their set ups just not regular music, so how about a 10 band eq to boost 32hz band? Basshead not audiophile
Soccerballzs Posted February 17, 2014 Report Posted February 17, 2014 What kind of sub? Cube ft of box? Port size. brand of amp? http://www.stevemeadedesigns.com/board/garage/vehicle/2438-jeep-commander/I Pioneer P99RSAmpere 38002-Ampere 125/44-6.5 inch Hertz HSK XL Mids4-8 inch JL Audio ZR Midwoofer 2-5.25 Satori Mids2-Morel Tweeters, 2 Hertz Milles 3 inch on A pillars2-Hertz Silk tweeters DC Audio Level 5/12 Skyhigh Wire Mechman 320 XS Power D3100MO Funniest Thread of the Year 2013: http://www.stevemead...dy-being-a-pos/
White Lightning Posted February 17, 2014 Report Posted February 17, 2014 First off ... Not all setups are the same just because the amplifiers have the same specs ... Second ... Welcome to SMD brother !!! You need to check all aspects of the builds ... Correct power and electrical, adequate enclosure design, drivers used, vehicle type ... and anything else would have factors that cause this ... Not saying any of the amplifiers you listed as "cheap" or what not ... but the amplifier only makes up part of the system ... EQ ??? No ... I would focus on wiring, electrical, drivers, and enclosure design before you go a pointing fingers ... Independant crossover ?? depends on what equipment you have already. If the amplifier has it's own crossover, then adding additional crossovers wil throw your phasing off and could sound worse ... Hope this helps some ... after all, these are only just my suggestions here ... Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
chrisw. Posted February 17, 2014 Report Posted February 17, 2014 I've noticed this too. Bottom line buy quality amps Still Living in the 90's MTX Thunder 2300x MTX Thunder 2150x MTX Thunder 275x MTX Thunder 1500dx <---still searching
33hz Posted February 17, 2014 Author Report Posted February 17, 2014 Ok for example, in my ford focus hatchback I run a kicker zx750.1 on a single 12" typeR, 2.2ft^3 32hz ported box. I run the crossover at 80hz, bass boost -0 and set the gain with a DD-1. Amps I've had in my car with this same sub/wiring are, jl 500/1, rf punch 800a2, alpine mrp m500, jbl 1200.1 and hifonics 1200w (not sure the model) Crossovers set @80hz, bass boost off, gain set with a DD-1. The RF, JL and Kicker all hit the 30hz-34hz range with authority while the alpine, JBL and Hifonics all struggled to sound balanced. The lows were there but did play with force. Basshead not audiophile
33hz Posted February 17, 2014 Author Report Posted February 17, 2014 ^did not hit with force* Basshead not audiophile
sbg Posted February 17, 2014 Report Posted February 17, 2014 I have had a bunch of cheap amps. And never had your problem. I Run a BRZ 2400 right now. And will play 26-30hz with authority. And my box is tuned to 41 hz. 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
bigmizzle99 Posted February 17, 2014 Report Posted February 17, 2014 This is a topic that I don't see mentioned much, and that is how an amp *sounds*. Its commonplace in home audio to compare and review amps and judge them on how they sound, but in car audio I never see much about how the amp sounds, only about how much power it makes. I'm interested to see what others think about sonic qualities of car amps. I understand the environment is completely different, but all things being equal, like OP stated, you should be able to judge how an amp sounds (at least to yourself) Camaro SS Build Altima build 2.0 Altima build 1.0
John Fassetta Posted February 17, 2014 Report Posted February 17, 2014 I've got a friend who's pretty insistent that certain amps make more power at certain frequencies (like horsepower at certain RPMs in an engine) or one can be much punchier than another. I've always felt like he just can't get out of the gearhead mindset, but maybe there is something to it? My only guesses are that I believe impedance raises at lower frequencies and budget amps are already pushed closer to the limit so they drop off in wattage more against higher resistance. Or that people with budget amps are less likely to buy nicer subs and spend the time building proper enclosures. I think probably more of the second.
