CleanSierra Posted December 8, 2014 Author Report Share Posted December 8, 2014 I will do some testing with 45s this week and see what we have. I'm also going to start planning out the cab bracing and how to make EVERYTHING pretty. I'm also thinking if getting a Matrix to get voltage up. I've heard that the PRS80 can struggle a bit with SPL builds from overprocessing Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
bcbrassard Posted December 8, 2014 Report Share Posted December 8, 2014 Never heard that about the 80-PRS! explain please? Link to comment Share on other sites More sharing options...
CleanSierra Posted December 8, 2014 Author Report Share Posted December 8, 2014 Never heard that about the 80-PRS! explain please? I've heard from some that the preout voltage can be a bit low. Then I've heard others say they get 4.8V from them. I have heard of a truck to use a Matrix to get closer to 7V out. Local SQ guy who runs BOBOS(and wins) went from the 80PRS to a Kenwood eXcelon deck and noticed a solid 1 db gain from head unit swap only. I think his had a gremlin in it, but it was still a gain. It won't hurt if I can boost line voltage CLEANLY to the amp, so I think I'm going to try the Matrix to avoid swapping out headunits. It was the SQ guy's belief that the 80 just has too tight a grip on everything and tries to process too much. Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
bcbrassard Posted December 8, 2014 Report Share Posted December 8, 2014 Thank you for the explanation, Had me worried there for second! ha ha Since i am not chasing #'s i will chalk it up as good info. You box is looking sick. I hope the 45's raise your #'s. Link to comment Share on other sites More sharing options...
CleanSierra Posted December 8, 2014 Author Report Share Posted December 8, 2014 Thank you for the explanation, Had me worried there for second! ha ha Since i am not chasing #'s i will chalk it up as good info. You box is looking sick. I hope the 45's raise your #'s. Thank you sir. Once I get the box dialed in, I'll focus oh pretty again Thank you ALL for being tuned in and interested. I'm really proud of it so far. It demos like a champ Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
dolarbilz Posted December 8, 2014 Report Share Posted December 8, 2014 I've always done better numbers in other decks.I'm really thinking of switching to Kenwood. Not that I don't love my 99prs im over numbers more into loud and clean. Link to comment Share on other sites More sharing options...
Miguels Posted December 8, 2014 Report Share Posted December 8, 2014 Never heard that about the 80-PRS! explain please? I've heard from some that the preout voltage can be a bit low. Then I've heard others say they get 4.8V from them. I have heard of a truck to use a Matrix to get closer to 7V out. Local SQ guy who runs BOBOS(and wins) went from the 80PRS to a Kenwood eXcelon deck and noticed a solid 1 db gain from head unit swap only. I think his had a gremlin in it, but it was still a gain. It won't hurt if I can boost line voltage CLEANLY to the amp, so I think I'm going to try the Matrix to avoid swapping out headunits. It was the SQ guy's belief that the 80 just has too tight a grip on everything and tries to process too much. i dont think that would matter since you have the gain on the amp.. if the 80prs is doing too much and having a tight grip then you still have the gain to match pre amp output .. i think they got the HU that has more pre amp output and never set the gain properly to match that of the new HU. i have both head units 80prs and the kenwood exelon. the only difference is kenwood is easier to mess with my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/ Link to comment Share on other sites More sharing options...
CleanSierra Posted December 8, 2014 Author Report Share Posted December 8, 2014 I thought the same too, about gain matching. These are guys that test, tune, test, tune. They setup their stuff clean with O scope or DD-1. I know logic days it shouldn't make sense, but I know two guys that have seen measurable gains in SPL with either adding a Matrix or swapping got a different head unit. It seems like theory and real world vary with this HU(as far as gain matching, clean etc). I'm not going to give up on the HU, but if it's trying to over process something on the bass side, I'm going to find a way around it. Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
ChrispyShimp Posted December 12, 2014 Report Share Posted December 12, 2014 Is there an Excelon with TA? Awesome build by the way, the box is sweeeeeeet! Baltic or something else? I want to stain my next box, which might be soon. Lost a coil on one of my subs, hard bottomed too many times haha. Knowledge is the greatest tool in any garage. It's also the most priceless, and most easily shared. Here's my latest build. http://www.stevemeadedesigns.com/board/topic/181273-89-c1500-build-log/ Link to comment Share on other sites More sharing options...
CleanSierra Posted December 12, 2014 Author Report Share Posted December 12, 2014 Is there an Excelon with TA? Awesome build by the way, the box is sweeeeeeet! Baltic or something else? I want to stain my next box, which might be soon. Lost a coil on one of my subs, hard bottomed too many times haha. They do make a Kenwood eXcelon with Time alignment, yes. The wood I'm using is birch, not Baltic though. It's cabinet grade birch(can't render the letter designation). Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
