SMZ2 Posted February 27, 2014 Report Posted February 27, 2014 I'm working on a c pillar wall and in order for it to fit I had to incorporate some odd angles. Is there a good way to get the volume. I am trying to figure out a port to see if anything will work. If not I may just tear down and go with a normal ported box if it will fit. Thanks for the help. My Build Log!http://www.stevemead...nissan-xterror/ Check the Youtube Channel for Updates!http://www.youtube....ser/Xterror2002And Seller Feedbackhttp://www.stevemeadedesigns.com/board/topic/163179-bought-from-smz2/#entry2363713
tacomaguy1 Posted February 27, 2014 Report Posted February 27, 2014 See if you can break it into triangles, different sized rectangles/squares obviously Team Flex Issues
Amart88 Posted February 27, 2014 Report Posted February 27, 2014 build the shell as big as you can before the walls hit the cars body, Then do the roof and connect it with 45's over the gaps. My 2005 s10 blazer build. 4 zcon 18's walled.
SMZ2 Posted February 27, 2014 Author Report Posted February 27, 2014 build the shell as big as you can before the walls hit the cars body, Then do the roof and connect it with 45's over the gaps.Yeah I already built the shell but it could definitely be bigger. It doesn't go all the way to the roof but if I do a b pillar one day it will. My Build Log!http://www.stevemead...nissan-xterror/ Check the Youtube Channel for Updates!http://www.youtube....ser/Xterror2002And Seller Feedbackhttp://www.stevemeadedesigns.com/board/topic/163179-bought-from-smz2/#entry2363713
SMZ2 Posted February 27, 2014 Author Report Posted February 27, 2014 See if you can break it into triangles, different sized rectangles/squares obviouslyI'll try and do that. This will be interesting. I'm Glassing over the wheel wells too. My Build Log!http://www.stevemead...nissan-xterror/ Check the Youtube Channel for Updates!http://www.youtube....ser/Xterror2002And Seller Feedbackhttp://www.stevemeadedesigns.com/board/topic/163179-bought-from-smz2/#entry2363713
kdh Posted February 27, 2014 Report Posted February 27, 2014 kinda a crazy idea.. get a 12"x12"x12" box... that should be a single cube. Buy a huge bag of pop corn peanuts from a shipping supply store for about 50$. Fill box with peanuts, dump box into speaker box. Do this till your speaker box is completely full of peanuts, but count the number times you dumped peanuts into the box. That should get you pretty damn close to the airspace. hope that helps.
Amart88 Posted February 27, 2014 Report Posted February 27, 2014 build the shell as big as you can before the walls hit the cars body, Then do the roof and connect it with 45's over the gaps.Yeah I already built the shell but it could definitely be bigger. It doesn't go all the way to the roof but if I do a b pillar one day it will. My bad man, I miss read your post. So, try to do as tacomaguy said and break it up into sections. Do the square areas first. If, say you had 45's then calculate as a whole square and divide by 2. If its a bit of an off-angle do them in triangles. Look up how to find volume of different types of angles. There should be formulas. My 2005 s10 blazer build. 4 zcon 18's walled.
Kyblack76 Posted February 27, 2014 Report Posted February 27, 2014 See if you can break it into triangles, different sized rectangles/squares obviouslyI'll try and do that. This will be interesting. I'm Glassing over the wheel wells too. I did the same. Glassed over my wells, and have a odd shaped port. Honestly, just get it CLOSE, and dial in. Retards that think they are with in a hundredth (EDIT tenth, or even a single) because math says, they are high. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Kyblack76 Posted February 27, 2014 Report Posted February 27, 2014 The loudest and BAD ass sounding builds ive ever heard......... when i asked about some specs, Tuning more than most.... It was "shit.. low 30's i guess" or I think in the 30's or mid 35's id expect... Or I gunned for under 30... im not sure if i made it or Tuning???? i shot for port space... i have no idea. Just what ive ran into..lol. Then again.. those ive seen, are pretty hush.... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Wicks Posted February 27, 2014 Report Posted February 27, 2014 1.) Break the odd shape into known shapes and add together. This will get you close. 2.) Pour a known volume of water into the odd shape and count. A lil messy... Or my favorite..... 3.) This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
